BT.com
Wishlist
HPE ML10 GEN9 G4400 4GB Entry Level
HPE ML10 GEN9 G4400 4GB Entry...
£168.00
More than 50 in stock
£168.00
Add to wishlist
Delivery
Standard 1-3 working days
Are you searching for an entry-level server solution with performance and reliability for your valuable data to replace a standard desktop unit? The HPE ProLiant ML10 Gen9 Server provides server level performance in a quiet, compact size that is easy to deploy in your home or your small business. It's affordable price will drive you to your first server to replace previous workstation solutions. The expandability helps to deliver the required workloads and the performance will decrease potential data loss. As the lowest acquisition cost 1P tower in the Hewlett Packard Enterprise server family, the ML10 Gen9 Server is the right choice for your first server.
Low Acquisition Cost with Server Level Performance
The HPE ProLiant ML10 Gen9 Server offers the right server technology for home or small businesses looking for performance and features at an affordable price. Embedded Intel AMT Management module with remote console, Web browser GUI and remote power on/off. Intel chipset supports RSTe SATA RAID disk drives to improve the performance for workloads.
Efficiency and Expandability to Fit the Needs of Growing, Budget-Conscious Businesses
The HPE ProLiant ML10 Gen9 Server offers expandability with internal support for up to six Large Form Factor (LFF) disk drives and increased I/O expansion. Configured with the Unified Extensible Firmware Interface (UEFI) boot mode allows provisioning both locally and remotely with either Intelligent Provisioning or Scripting Toolkits. With the optional HPE H241 Smart Host Bus Adapter your get the flexibility to run in HBA mode or simple RAID mode. When operating in simple RAID mode, it provides RAID 0, RAID 1, and RAID 5 with optional HPE Secure Encryption capabilities.
Workstation Oriented Design for Better Performance
The HPE ProLiant ML10 Gen9 Server graphics processing unit (GPU) supports two single wide and one double wide GPU card to boost performance in graphic and VDI applications for financial services, education, scientific research, and medical imaging. It supports the Intel Xeon E3-1200 v5 processor in a 4U chassis offering increased performance and efficiency. Server class technology allows for 24x7 business operation, offering higher reliability and longer lifecycle.
Key Features - The HPE ProLiant ML10 Gen9 Server offers the right server technology for home or small businesses looking for performance and features at an affordable price - The HPE ProLiant ML10 Gen9 Server offers expandability with internal support for up to six Large Form Factor (LFF) disk drives and increased I/O expansion - The HPE ProLiant ML10 Gen9 Server graphics processing unit (GPU) supports two single wide and one double wide GPU card to boost performance in graphic and VDI applications for financial services, education, scientific research, and medical imaging
HPE ProLiant ML10 Gen9 Entry - Pentium G4400 3.3 GHz - 4 GB - 0 TB
Server - tower
Height (Rack Units)
4U
Europe
Server Scalability
1-way
1 x Intel Pentium G4400 / 3.3 GHz (Dual-Core)
Processor Socket
LGA1151 Socket
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 64 GB (max) - DDR4 SDRAM - ECC - PC4-17000
Storage Controller
RAID (SATA 6Gb/s)
Server Storage Bays
Non-hot-swap 3.5"
Hard Drive
No HDD
Graphics Controller
No graphics
GigE
17.5 cm x 40.13 cm x 36.76 cm
6.68 kg
1 year warranty - on-site
Server
Product Form Factor
Tower - 4U
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Server Scalability
1-way
Internal Bays Qty
4
Europe
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel C236
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 64 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
No HDD
Storage Controller
1 x RAID
Controller Interface Type
SATA 6Gb/s
Channel Qty
6
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Interface (Bus) Type
PCI Express x2
Ethernet Controller
Intel I219LM
PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Bays
4 (total) / 4 (free) x internal 3.5" LFF
Slots
4 (total) / 3 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x4 - half-length, full-height (x1 mode) , 1 (total) / 1 (free) x PCIe 3.0 x4 - half-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height (x8 mode) , 1 (total) / 1 (free) x PCIe 3.0 x8 - half-length, full-height
2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.0 , 3 x USB 2.0 (2 front, 1 internal)
Theft/Intrusion Protection
FCC Class B certified, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, WEEE, GB 9254, CNS 13438
Power supply
Nominal Voltage
Power Provided
300 Watt
Operating System / Software
OS Certified
SuSE Linux Enterprise Server, Microsoft Windows Server, Red Hat Enterprise Linux
Limited warranty - parts and labour - 1 year - on-site - response time: next business day
17.5 cm
40.13 cm
36.76 cm
6.68 kg
10 °C
35 °C
8 - 90%
Sound Emission
22 dBA
Other bundles
£168.00
Protect your Purchase!
Save £29.00
£178.99
£168.00
Keep your device tuned up!
£177.99
Scroll to top
