BT.com
Wishlist
HPE LTO-6 Ultrium 6250 Int Tape Drive
HPE LTO-6 Ultrium 6250 Int Tape...
£2,347.35
Hurry, only 2 left in stock!
£2,347.35
Add to wishlist
Delivery
Standard 1-3 working days
HPE StoreEver LTO Ultrium Tape Drives represent seven-generations of LTO technology capable of storing up to 15 TB per cartridge, with HPE TapeAssure for manageability, hardware data encryption, HPE StoreOpen with LTFS for ease of use at an unprecedented performance. With HPE TapeAssure customers can be confident that their data is safe by monitoring drive and media utilization, operational performance and life/health information for drive and media. Data hardware encryption using AES 256-bit provides easy-to-enable security to protect the most sensitive data and prevent unauthorized access of tape cartridges. Linear Tape File System (LTFS) is an open format for storing data on tape that makes LTO generation 5 and later tapes self-describing and file-based. Capable of data transfer rates up to 300 MB/sec native, HPE's Data Rate Matching further optimizes performance by matching host system speed to keep drives streaming, thus enabling the fastest tape performance.
HPE StoreEver LTO-6 Ultrium 6250 - tape drive - LTO Ultrium - SAS-2
Tape drive
Recording Standard
LTO Ultrium 6
Enclosure Type
Internal
Interface Type
SAS-2
Key Features
Encryption
14.5 cm x 20.6 cm x 4.1 cm
1.45 kg
Storage Removable
LTO Ultrium - 5.25" x 1/2H
Storage Removable Capacity
2.5 TB (native) / 6.25 TB (compressed)
Supported Tape Cartridges (Read and Write)
Ultrium 6, Ultrium 5
Data Transfer Rate (native)
160 MBps (576 GBph)
Data Transfer Rate (compressed)
400 MBps (1440 GBph)
ProLiant DL320e Gen8, DL360 G7, DL360e Gen8, DL360p Gen8, DL380 G7, DL380e Gen8, DL380p Gen8, DL385p Gen8, DL560 Gen8, ML350e Gen8, ML350p Gen8, SL230s Gen8, SL270s Gen8
Tape drive - LTO Ultrium
Recording Standard
LTO Ultrium 6
Enclosure Type
Internal
Interface Type
SAS-2
Key Features
Encryption
14.5 cm
20.6 cm
4.1 cm
1.45 kg
Storage Removable
Recording Standard
Ultrium 5, Ultrium 6
160 MBps (576 GBph)
Average Seek / Access Time
50 sec
Buffer Size
512 MB
1 x SAS-2 - 29 pin internal SAS (SFF-8482)
Compatible Bay
1 x front accessible - 5.25" x 1/2H
Media Included Qty
1
1 x SAS cable
MTBF
250,000 hour(s)
TUV, VCCI, C-Tick, BSMI, EN 60950, NOM, RRL, IEC 60950, CSA 22.2 No. 60950, CB, RoHS, FCC CFR47 Part 15, cCSAus
Software Included
HP Library and Tape Tools
10 °C
35 °C
20 - 80% (non-condensing)
HPE ProLiant DL320e Gen8 Entry, DL360 G7, DL360e Gen8, DL360e Gen8 Base, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL380 G7, DL380e Gen8, DL380e Gen8 Base, DL380e Gen8 Entry, DL380e Gen8 High Performance, DL380e Gen8 Storage, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL385p Gen8 Storage Centric, DL560 Gen8, DL560 Gen8 Base, DL560 Gen8 Entry, DL560 Gen8 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2, ML350p Gen8, ML350p Gen8 Base, ML350p Gen8 Entry, ML350p Gen8 Performance, ML350p Gen8 Special Server, SL230s Gen8 1U Left Half Width Tray, SL230s Gen8 1U Right Half Width Tray, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray
Scroll to top
