BT.com
Wishlist
HPE LTO-5 Ultrium 3000 SAS Internal Tape Drive
HPE LTO-5 Ultrium 3000 SAS Internal...
£1,546.66
Hurry, only 1 left in stock!
£1,546.66
Add to wishlist
Delivery
Standard 1-3 working days
HPE StoreEver LTO Ultrium Tape Drives represent seven-generations of LTO technology capable of storing up to 15 TB per cartridge, with HPE TapeAssure for manageability, hardware data encryption, HPE StoreOpen with LTFS for ease of use at an unprecedented performance. With HPE TapeAssure customers can be confident that their data is safe by monitoring drive and media utilization, operational performance and life/health information for drive and media. Data hardware encryption using AES 256-bit provides easy-to-enable security to protect the most sensitive data and prevent unauthorized access of tape cartridges. Linear Tape File System (LTFS) is an open format for storing data on tape that makes LTO generation 5 and later tapes self-describing and file-based. Capable of data transfer rates up to 300 MB/sec native, HPE's Data Rate Matching further optimizes performance by matching host system speed to keep drives streaming, thus enabling the fastest tape performance.
HPE LTO-5 Ultrium 3000 - tape drive - LTO Ultrium - SAS-2
Tape drive
Recording Standard
LTO Ultrium 5
Enclosure Type
Internal
Interface Type
SAS-2
Key Features
Encryption
14.5 cm x 20.6 cm x 4.1 cm
1.45 kg
Storage Removable
LTO Ultrium - 5.25" x 1/2H
Storage Removable Capacity
1.5 TB (native) / 3 TB (compressed)
Supported Tape Cartridges (Read and Write)
Ultrium 4, Ultrium 5
Data Transfer Rate (native)
140 MBps (504 GBph)
Data Transfer Rate (compressed)
280 MBps (1008 GBph)
IBM AIX, SunSoft Solaris, HP-UX, Red Hat Linux, SuSe Linux, Microsoft Windows, HP Tru64 UNIX
3 years warranty
ProLiant DL360e Gen8, DL360p Gen8, DL370 G6, DL380e Gen8, DL380p Gen8, DL385p Gen8, DL560 Gen8, ML110 G6, ML110 G7, ML150 G6, ML310e Gen8, ML330 G6, ML350 G6, ML350e Gen8, ML350p Gen8; StorageWorks Rack-Mount Kit Ultrium 1760
Tape drive - LTO Ultrium
Recording Standard
LTO Ultrium 5
Enclosure Type
Internal
Interface Type
SAS-2
Key Features
Encryption
14.5 cm
20.6 cm
4.1 cm
1.45 kg
Storage Removable
Recording Standard
140 MBps (504 GBph)
Buffer Size
256 MB
1 x SAS-2 - 29 pin internal SAS (SFF-8482)
Compatible Bay
1 x front accessible - 5.25" x 1/2H
Media Included Qty
1
1 x SAS cable
MTBF
250,000 hour(s)
TUV, VCCI, C-Tick, BSMI, EN 60950, NOM, RRL, IEC 60950, CSA 22.2 No. 60950, CB, FCC CFR47 Part 15, AES-256
Software Included
Drivers & Utilities, Yosemite Backup Basic, HP Library and Tape Tools
Limited warranty - 3 years - response time: next day , Technical support - phone consulting - 3 years
10 °C
20 - 80% (non-condensing)
HPE ProLiant DL360e Gen8, DL360e Gen8 Base, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL370 G6 Base, DL370 G6 High Performance, DL380e Gen8, DL380e Gen8 Base, DL380e Gen8 Entry, DL380e Gen8 High Performance, DL380e Gen8 Storage, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL385p Gen8 Storage Centric, DL560 Gen8, DL560 Gen8 Base, DL560 Gen8 Entry, DL560 Gen8 Performance, ML110 G6, ML110 G7, ML150 G6, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML330 G6, ML350 G6, ML350 G6 Base, ML350 G6 Performance, ML350 G6 Special Server, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350p Gen8, ML350p Gen8 Base, ML350p Gen8 Entry, ML350p Gen8 Performance, ML350p Gen8 Special Server , HPE StorageWorks Rack-Mount Kit Ultrium 1760 Drive
Scroll to top
