BT.com
Wishlist
HPE LTO-4 Ultrium 1.6 TB WORM Custom Labelled Data Cart 20 pk
HPE LTO-4 Ultrium 1.6 TB WORM...
£917.44
£917.44
Add to wishlist
Delivery
Standard Due date unavailable
With HP Custom Labeled Media, you no longer have to label your own cartridges, saving you time and the risk of retrieval errors. For no extra charge, cartridges can be supplied with barcode labels bearing your own specified sequences. HP rigorously tests its precision-engineered, high-resolution barcode labels using software unique to the HP Automation Group to evaluate and warrant the performance of its labels. These labels are professionally applied in a clean environment to ensure 100% readability accurate storage and retrieval in busy, automated tape libraries. Custom labeled cartridges ensure 100% label readability and can be ordered online in packs of 20. For those customers who value the added security that RFID adds, customers have the option to integrate it into each label at minimal cost. The RFID tag is embedded into the back of the customized label and offers tracking, audit and security advantages for those with IT asset tracking systems.
HPE Ultrium WORM Custom Labeled Data Cartridge - LTO Ultrium WORM x 20 - 800 GB - storage media
Storage media - LTO Ultrium WORM
Tape Cartridge
Ultrium 4
Media Included Qty
20
Native Capacity
800 GB
Compressed Capacity
1.6 TB
Tape Length
820 m
Cartridge Labeling
Labeled
Metal Particle (MP)
HPE MSL2024, MSL4048; 1/8 G2 Tape Autoloader; StorageWorks MSL2024, MSL4048, MSL6030, MSL6060, MSL8096, SAS Rack-Mount Kit, Ultrium 1840; StorageWorks Enterprise Modular Library E-Series; StorageWorks Ultrium 1840; StoreEver Ultrium 1840
LTO Ultrium WORM
Tape Cartridge
Ultrium 4
Media Included Qty
20
Cartridge Labeling
Labeled
Media
Native Capacity
800 GB
Compressed Capacity
1.6 TB
Tape Length
820 m
Archival Life
30 years
Metal Particle (MP)
10 °C
45 °C
20 - 80%
Min Storage Temperature
16 °C
Max Storage Temperature
32 °C
HPE MSL2024 Ultrium 1760, MSL2024 Ultrium 1840, MSL4048 Ultrium 1760 , HPE 1/8 G2 Tape Autoloader Ultrium 1760 , HPE StorageWorks MSL2024 Ultrium 1840, MSL4048 Ultrium 1840, MSL6030 Ultrium 1840, MSL6060 Ultrium 1840, MSL8096 Ultrium 1840, SAS Rack-Mount Kit, Ultrium 1840 Drive Upgrade Kit , HPE StorageWorks Enterprise Modular Library E-Series , HPE StorageWorks Ultrium 1840, 1840 Array Module, 1840 FC Drive Kit , HPE StoreEver Ultrium 1840 Drive Upgrade Kit
Scroll to top
