BT.com
Wishlist
HPE LTO-4 Ultrium 1.6 TB RW RFID Non-Custom Labelled Cart 20pk
Delivery
Standard Due date unavailable
With HPE Non-custom Labeled LTO Ultrium media, you no longer have to label your own cartridges, saving you time and the risk of retrieval errors. Barcode sequences are unique to each batch ordered – no codes are repeated. HPE rigorously tests its precision-engineered, high-resolution barcode labels using software unique to the HPE Automation Group to evaluate and warrant the performance of its labels in demanding, split-second datacenter environments. These labels are professionally applied in a clean environment to ensuring 100% readability accurate storage. Non-Custom Labeled cartridges ensure 100% label readability and can be ordered online, in packs of 20, using a fast and simple process. For those customer who value the added security that RFID adds, customers have the option to integrate it into each label at minimal cost. The RFID tag is embedded into the back of the non-custom label and offers tracking, audit and security advantages for those with IT asset tracking systems.
HPE Ultrium RFID Non Custom Labeled Data Cartridge - LTO Ultrium x 20 - 800 GB - storage media
Storage media - LTO Ultrium
Tape Cartridge
Ultrium 4
Media Included Qty
20
Green
Native Capacity
800 GB
Compressed Capacity
1.6 TB
Tape Length
820 m
Metal Particle (MP)
ProLiant DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance; StorageWorks SAS Rack-Mount Kit
LTO Ultrium
Tape Cartridge
Ultrium 4
Media Included Qty
20
Green
Media
Native Capacity
800 GB
Compressed Capacity
1.6 TB
Tape Length
820 m
Archival Life
30 years
Metal Particle (MP)
10 °C
45 °C
10 - 80%
Min Storage Temperature
16 °C
Max Storage Temperature
32 °C
HPE ProLiant DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance , HPE StorageWorks SAS Rack-Mount Kit
Scroll to top
