BT.com
Wishlist
HPE Jetdirect ew2500 802.11g Print Server
HPE Jetdirect ew2500 802.11g Print...
£263.38
£263.38
Add to wishlist
Delivery
Standard 1-3 working days
HP Jetdirect ew2500 802.11b/g Wireless Print Server
Get the best of both worlds - share HP printers and multifunction products via wireless or wired networks. Send and print documents protected by IPSec, 802.11x and several encryption options. Enjoy easy installation, set up and management.
HP JetDirect ew2500 - print server
Print server
External
Interface (Bus) Type
USB 2.0
Ports
10/100 Ethernet
10 cm x 13.5 cm x 3.3 cm
140 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN, 802.11b, 802.11g
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x
1 year warranty
Color LaserJet CP3505; Color LaserJet Enterprise M651; Color LaserJet Managed M651; LaserJet Enterprise MFP M525, MFP M575, MFP M630, P3015; LaserJet Enterprise Flow MFP M880; LaserJet Managed MFP M525; LaserJet Managed Flow MFP M525, MFP M880; Officejet X585; Officejet Enterprise Color X555
Print server
External
USB 2.0
Ports
10/100 Ethernet
Wireless, wired
Cabling Type
Remote Management Protocol
SNMP 3, HTTPS
1 x 100Base-TX - RJ-45
1 x USB 2.0
1 x USB cable (external) , 1 x network cable (external)
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 40-bit WEP, 104-bit WEP, TKIP, WPA, WPA2
Software Included
Drivers & Utilities
10 cm
13.5 cm
3.3 cm
140 g
Limited warranty - 1 year
HP Color LaserJet 2700, 2700n, CM1015 MFP, CM1017 MFP, CM3530 MFP, CM3530fs MFP, CM4730 MFP, CM4730f MFP, CM4730fm MFP, CM4730fsk MFP, CM6030 MFP, CM6030f MFP, CM6040 MFP, CM6040f MFP, CP1510, CP1515n, CP1518ni, CP2025, CP2025dn, CP2025n, CP2025x, CP3505, CP3505dn, CP3505n, CP3505x, CP3525, CP3525dn, CP3525n, CP3525x, CP4005dn, CP4005n, CP6015de, CP6015dn, CP6015n, CP6015x, CP6015xh , HP Color LaserJet Enterprise CP4025dn, CP4025n, CP4525dn, CP4525n, CP4525xh, CP5525dn, CP5525n, CP5525xh, M651dn, M651n, M651xh , HP Color LaserJet Managed M651dnm, M651xhm , HP Color LaserJet Professional CP5225, CP5225dn, CP5225n , HP DesignJet T120 ePrinter, T520 ePrinter , HP LaserJet 4240, 5200dtn, 5200L, 5200Lx, 5200n, M3027 MFP, M3027x MFP, M3035 MFP, M3035xs MFP, M4345 MFP, M4345x MFP, M4345xm MFP, M4345xs MFP, M5025 MFP, M5035 MFP, M5035x MFP, M5035xs MFP, M9040 MFP, M9050 MFP, P2014, P2014n, P2015, P2015d, P2015dn, P2015n, P2015x, P2035, P2035n, P2055d, P2055dn, P2055x, P3005, P3005d, P3005dn, P3005n, P3005x, P4014, P4014dn, P4014n, P4015dn, P4015n, P4015tn, P4015x, P4515n, P4515tn, P4515x, P4515xm , HP LaserJet Enterprise 500 M551dn, 600 M601n, M4555 MFP, M4555f MFP, M4555fskm MFP, M4555h MFP, MFP M525dn, MFP M525f, MFP M575f, MFP M630dn, P3015, P3015d, P3015dn, P3015n, P3015x , HP LaserJet Enterprise Flow MFP M880z, MFP M880z+, MFP M880z+ NFC/Wireless direct , HP LaserJet Managed MFP M525fm , HP LaserJet Managed Flow MFP M525cm, MFP M880zm, MFP M880zm+ , HP LaserJet Pro P1606DN , HP Officejet X585dnm, X585zm , HP Officejet Enterprise Color X555dn, X555xh , HP Officejet Pro 8000, 8000 Enterprise, 8000 Wireless, 8500 A909a, 8500 Premier A909n, 8500 Wireless A909g, 8500A A910a, 8500A Plus A910g, 8600 N911a, 8600 Plus N911g, 8600 Premium N911n, K5300, K5400, K5400dn, K5400dtn, K5400n, K5400tn, K550, K550dtn, K550dtwn, K850, K850dn, K8600, K8600dn, L7380, L7550, L7555, L7580, L7590, L7650, L7680, L7681, L7710, L7750, L7780
Scroll to top
