BT.com
Wishlist
HPE JetDirect 620N Fast Ethernet EIO RJ45 Int Print
HPE JetDirect 620N Fast Ethernet...
£395.49
£395.49
Add to wishlist
Delivery
Standard Due date unavailable
With advanced security and industry-leading performance, the HP Jetdirect 620n Fast Ethernet Internal Print Server enables businesses to share HP printers with EIO slots, easily and affordably across the network and the Internet.
HP JetDirect 620n - print server
Print server
Plug-in module
Interface (Bus) Type
EIO
Ports
10/100 Ethernet
8.9 cm x 13.6 cm x 3.1 cm
72 g
Europe
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Network / Transport Protocol
TCP/IP, IPX/SPX, AppleTalk, DLC/LLC
RAM
16 MB
IEEE 802.3, IEEE 802.1x
Microsoft Windows 98, Microsoft Windows NT 4.0, Novell NetWare 3.2, HP-UX 10.20, SunSoft Solaris 2.6, SunSoft Solaris 7, Novell NetWare 4.2, SunSoft Solaris 2.5 or later, IBM AIX 3.2.5 or later, Microsoft Windows 2000, HP-UX 11.x, Apple MacOS 8.6 or later, SunSoft Solaris 8, HP MPE/iX, Novell NetWare 5.x, SuSE Linux 6.x, Microsoft Windows Millennium Edition, Citrix Presentation Server, Novell NetWare 6.x, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Red Hat Linux 6.x, Microsoft Windows Server 2003, SCO OpenServer 5.x
1 year warranty
Business Inkjet 2300, 2800; Color LaserJet 3000, 3700, 3800, 4700, 85XX, 9500, CM6030, CP3525, CP6015; Color LaserJet Enterprise CP5525; DesignJet 500, 510, 5100, 90, T1100, T610; LaserJet 24XX, 42XX, 43XX, 5200, 90XX, M3027, M9040, M9050, P3005, P4014, P4015, P4515; LaserJet Enterprise M5039, P3015
Print server
Plug-in module
EIO
Europe
Ports
10/100 Ethernet
Wired
Cabling Type
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, NCP, SNMP 2c, HTTP, NDS, HTTPS
DHCP support, BOOTP support, IGMP snooping, firmware upgradable
Processor / Memory
RAM
16 MB
Flash Memory
4 MB
1 x 100Base-TX - RJ-45
Compatible Slots
1 x EIO
Encryption Algorithm
SSL, TLS
EN 60950, IEC950, FCC Part 15 B, DOC, AS/NZS 3548
Software Included
Drivers & Utilities
8.9 cm
13.6 cm
3.1 cm
72 g
Limited warranty - 1 year
55 °C
0 - 95%
HP Business Inkjet 2200, 2200se, 2200xi, 2230, 2250, 2280, 2300, 2300dtn, 2300n, 2600, 2800, 2800DT, 2800dtn, 3000 , HP Color LaserJet 2500, 2500L, 2500Lse, 2500n, 2500tn, 3000, 3000dn, 3000dtn, 3000n, 3700, 3700d, 3700dn, 3700dtn, 3700n, 3800, 3800dn, 3800dtn, 3800n, 4550DN Plus, 4550HDN Plus, 4550N Plus, 4600, 4600dn, 4600dtn, 4600hdn, 4600n, 4650, 4650dn, 4650dtn, 4650hdn, 4650n, 4700, 4700dn, 4700dtn, 4700n, 4700ph+, 5500, 5500dn, 5500dtn, 5500hdn, 5500n, 5550, 5550dn, 5550dtn, 5550hdn, 5550n, 8500gn, 8550, 8550dn, 8550dn Plus, 8550gn, 8550gn Plus, 8550mfp, 8550n, 8550n Plus, 9500gp, 9500hdn, 9500mfp, 9500n, CM6030 MFP, CM6030f MFP, CP3525dn, CP3525n, CP3525x, CP6015de, CP6015n, CP6015x, CP6015xh , HP Color LaserJet Enterprise CP5525dn, CP5525n, CP5525xh , HP DesignJet 100, 1050c plus, 1055cm plus, 10ps, 110Plus, 120, 120nr, 20ps, 4000, 500 Plus, 50ps, 510, 5100, 510ps, 5500, 5500ps, 815mfp, 90r, T1100, T1100 MFP, T1100ps, T610 , HP Digital Sender 9200C , HP LaserJet 2200, 2200d, 2200dn, 2200dse, 2200dt, 2200dtn, 2300, 2300d, 2300dn, 2300dtn, 2300l, 2300n, 2410, 2420, 2420d, 2420dn, 2420n, 2430, 2430dtn, 2430n, 2430t, 2430tn, 4050se, 4100mfp, 4200, 4200dtn, 4200dtns, 4200dtnsl, 4200L, 4200Ln, 4200Lvn, 4200n, 4200tn, 4240n, 4250, 4250dtn, 4250dtnsl, 4250n, 4250tn, 4300, 4300dtn, 4300dtns, 4300dtnsl, 4300n, 4300tn, 4345mfp, 4345x mfp, 4345xm mfp, 4345xs mfp, 4350, 4350dtn, 4350dtnsl, 4350n, 4350tn, 5000dn, 5000LE, 5100, 5100dtn, 5100Le, 5100n, 5100se, 5100tn, 5200, 5200dtn, 5200L, 5200n, 5200tn, 8000mfp, 8150mfp, 9000, 9000dn, 9000hn, 9000hnf, 9000hns, 9000L MFP, 9000mfp, 9000n, 9040, 9040dn, 9040mfp, 9040n, 9050, 9050dn, 9050mfp, 9050n, 9055mfp, 9065mfp, M3027 MFP, M3027x MFP, M9040 MFP, M9050 MFP, P3005, P3005d, P3005dn, P3005n, P3005x, P4014dn, P4015n, P4015tn, P4015x, P4515n, P4515tn, P4515x, P4515xm , HP LaserJet Enterprise M5039xs MFP, P3015, P3015d, P3015dn, P3015n, P3015x , HP Officejet 9110, 9120, 9130
Scroll to top
