BT.com
Wishlist
HPE HP X540-T2 10GbE Dual Port Adapter
HPE HP X540-T2 10GbE Dual Port...
£650.22
£650.22
Add to wishlist
Delivery
Standard 1-3 working days
Enjoy flexible and scalable high-performance Ethernet connectivity in workstation, virtual workstation, and cloud computing environments with an Intel X540 10Gb Ethernet Dual Port Adapter.
Intel X540-T2 - network adapter
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.1
PCI Specification Revision
PCIe 2.1
Ports
10GBase-T x 2
1.8 cm x 15.2 cm x 6.9 cm
Cabling Type
Ethernet 10GBase-T
GigE, 10 GigE
Data Transfer Rate
10 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP
IEEE 802.1Q
Microsoft Windows 7, Linux 2.6.x, SuSE Linux Enterprise Server 11, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008 SP2, Microsoft Windows Vista SP2, SuSE Linux Enterprise Server 10, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Microsoft Windows Server 2003 SP2, Red Hat Enterprise Linux 6, VMware ESXi, Windows 8, Microsoft Windows Server 2012, VMware ESX, Linux 3.x, FreeBSD 9, Microsoft Windows Server 2012 R2
Workstation Z440, Z640, Z840
Network adapter
PCI Express 2.1
PCIe 2.1
Ports
10GBase-T x 2
Wired
Cabling Type
Ethernet 10GBase-T
GigE, 10 GigE
Data Transfer Rate
10 Gbps
TCP/IP, UDP/IP
Auto-negotiation, VLAN support, IPv6 support, full duplex mode, TCP/IP offloading, Jumbo Frames support, IPv4 support, teaming support, PXE support, Large Send Offload (LSO), Receive Side Scaling (RSS), Single Root I/O Virtualization (SR-IOV), TCP Segmentation Offload (TSO), checksum offload support, Extended Message-Signaled Interrupts (MSI-X), Network Bonding support, Precision Time Protocol (PTP), UDP/IP checksum offload
IEEE 802.1Q
2 x 10GBase-T
1.8 cm
15.2 cm
6.9 cm
55 °C
5 - 95% (non-condensing)
HP Workstation Z440, Z640, Z840
Scroll to top
