BT.com
Wishlist
HPE HP X132 10G SFP+ LC LR Transceiver
HPE HP X132 10G SFP+ LC LR...
£987.58
£987.58
Add to wishlist
Delivery
Standard Due date unavailable
A 10-Gigabit transceiver in SFP+ form-factor that supports the 10-Gigabit LR standard, providing 10-Gigabit connectivity up to 10 km on single-mode fiber.
HPE - SFP+ transceiver module - 10 Gigabit Ethernet
SFP+ transceiver module - LC/UPC single-mode
Plug-in module
Cabling Type
10GBase-LR
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 Gigabit Ethernet
Max Transfer Distance
10 km
1.4 cm x 5.6 cm x 1.2 cm
20 g
Aruba 2930F 24G 4SFP+, 2930F 24G PoE+ 4SFP+, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP+, 5406 zl; HP SFP+ zl Module Rack Shippable; HPE 2-Port SFP+/ 2-Port CX4 10GbE yl Module, 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch, SFP+ zl
Plug-in module
Wired
Cabling Type
10GBase-LR
10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Optical Wave Length
1310 nm
10 km
IEEE 802.3ae
1 x Ethernet 10GBase-LR - LC/UPC single-mode x 2
Compatible Slots
1 x SFP+
1.4 cm
5.6 cm
1.2 cm
20 g
70 °C
Aruba 2930F 24G 4SFP+, 2930F 24G PoE+ 4SFP+, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP+, 5406 zl , HP SFP+ zl Module Rack Shippable , HPE 2-Port SFP+/ 2-Port CX4 10GbE yl Module, 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch, SFP+ zl
Accessories
£12.32
£13.96
£18.08
£23.01
Scroll to top
