BT.com
Wishlist
HPE HP V1410-16 16-Port L3 Unmanaged Switch
HPE HP V1410-16 16-Port L3...
£66.56
17 in stock
£66.56
Add to wishlist
Delivery
Standard 3-5 working days
The HPE 1410 Switch Series consists of unmanaged switches designed for small businesses looking for entry-level, low-cost, reliable networking solutions. Available features include flow control to provide outstanding data efficiency, simplified plug-and-play operation, Auto-MDIX, auto-speed negotiation, flexible mounting options, and Limited Lifetime Warranty. All models have Quality of Service (QoS) support and IEEE 802.3x flow control features. Plug-and-play convenience is enabled by auto-MDIX and auto-speed negotiation.
HPE 1410-16 Switch - switch - 16 ports - unmanaged
Switch - 16 ports - L3 - unmanaged
Subtype
Fast Ethernet
Ports
16 x 10/100
Performance
Switching capacity: 3.2 Gbps
MAC Address Table Size
8K entries
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), half duplex mode, full duplex mode, Quality of Service (QoS), fanless, Mini Jumbo Frame support
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
AC 120/230 V (50/60 Hz) 300 mA (operating)
20.9 cm x 10.7 cm x 4.4 cm
0.65 kg
Bundled Services
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
16 x 10/100
Performance
8K entries
Flash Memory
512 KB
Status Indicators
Link activity, port transmission speed, port duplex mode, status
16 x 100Base-TX - RJ-45
External power adapter
Electric Current Required
300 mA (operating)
3.6 Watt
Rack Mounting Kit
Included
FCC Class A certified, CISPR 24, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN55024, CISPR 22, CSA 22.2 No. 60950, FCC Part 15 B, UL 60950-1, IEC 60950-1, EN 60950-1
20.9 cm
10.7 cm
4.4 cm
0.65 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
15 - 90% (non-condensing)
Accessories
£4.95
£3.74
£11.19
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.02
£50.74
Scroll to top
