BT.com
Wishlist
HPE HP StorageWorks D2200sb PCIe Storage Blade Hard Drive Array
HPE HP StorageWorks D2200sb PCIe...
£1,424.78
£1,424.78
Add to wishlist
Delivery
Standard Due date unavailable
Do you need a direct attached or shared storage solution within your BladeSystem enclosure? The D2200sb Storage Blade delivers direct attached storage for c-Class servers, with support for up to twelve SFF SAS hard disk drives or SAS/SATA SSDs or SATA Midline hard drives. The enclosure backplane provides a PCI Express connection to the adjacent c-Class server blade and enables high performance storage access without any additional cables. The D2200sb features the onboard Smart Array P410i controller with 1 GB flash-backed write cache, for increased performance and data protection. Use the HP StoreVirtual VSA to turn the D2200sb into an iSCSI SAN for use by all severs in the enclosure and any server on the network. VSA includes remote replication capabilities, thin provisioning, and snapshot. Combine the D2200sb with the HP X1800sb Network Storage Blade to enable file serving iSCSI shared storage inside the BladeSystem enclosure.
HPE StorageWorks D2200sb PCIe Storage Blade - hard drive array
Hard drive array
Total Array Capacity
7.2 TB
SAS 6Gb/s
12 (max)
Supported Drives
SAS-2
Storage Controller
RAID (SAS 6Gb/s) - RAID 0, 5, 6, 10, ADG
Hard Drive
No HDD
18.1 cm x 51.6 cm x 5.3 cm
3.9 kg
3 years warranty
Integrity BL860c i4; ProLiant BL660c Gen8, BL660c Gen8 Performance, WS460c Gen8
Hard drive array
Chassis
Supported Devices / Modules Qty
12
Supported Drives
SAS-2
Storage
7.2 TB
HDD Array External Interface
SAS 6Gb/s
Storage Controller
RAID
Interface Type
SAS 6Gb/s
Data Transfer Rate
600 MBps
Cache / Buffer Size (Max)
1 GB
Max Storage Devices Qty
32
RAID Level
RAID 0, RAID 5, RAID 6, RAID 10, ADG
Hard Drive
No HDD
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" SFF
18.1 cm
51.6 cm
5.3 cm
3.9 kg
Limited warranty - parts and labour - 3 years - on-site
10 °C
35 °C
20 - 80% (non-condensing)
HPE Integrity BL860c i4 , HPE ProLiant BL660c Gen8, BL660c Gen8 Performance, WS460c Gen8
Scroll to top
