BT.com
Wishlist
HPE HP SFP (mini-GBIC) Transceiver Module
HPE HP SFP (mini-GBIC) Transceiver...
£76.11
14 in stock
£76.11
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Wednesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
It offers a small form-factor pluggable (SFP) Gigabit SX transceiver that provides a full-duplex Gigabit solution up to 550 m on multimode fiber.
HPE - SFP (mini-GBIC) transceiver module - Gigabit Ethernet
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Gigabit Ethernet
Max Transfer Distance
550 m
1.37 cm x 5.69 cm x 1.22 cm
20 g
Aruba 2530, 2930F 24, 2930F 48, 5406, Switch 5400zl 24; HP Switch 2910al-24, Switch 2910al-48; HPE 1700, 1810, 1910, 20p 10/100/1000, 2610, 2810, 2910, 3500, 6120, 6200, 6600, Switch 1800-24, Switch 2900-24, Switch 2900-48, Switch 8212, Switch vl 4-port, Switch XL 10/100/1000, V1400, vl 20
Plug-in module
Wired
Cabling Type
1000Base-SX
Gigabit Ethernet
Data Transfer Rate
1 Gbps
550 m
Full duplex capability
IEEE 802.3z
1 x Ethernet 1000Base-SX - LC multi-mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
1.37 cm
5.69 cm
1.22 cm
20 g
Aruba 2530-24G, 2530-24G-PoE+, 2530-48G, 2530-48G-PoE+, 2530-48-PoE+, 2930F 24G 4SFP, 2930F 24G 4SFP+, 2930F 24G PoE+ 4SFP, 2930F 24G PoE+ 4SFP+, 2930F 48G 4SFP, 2930F 48G 4SFP+, 2930F 48G PoE+ 4SFP, 2930F 48G PoE+ 4SFP+, 5406 zl, Switch 5400zl 24p Mini-GBIC Module , HP 9400sl 40-Port Mini-GBIC Module, EP Redundant Management Module, Switch 2510-24, Switch 2510-48, Switch 2510G-24, Switch 2510G-48, Switch 2610-24, Switch 2610-24/12-PWR, Switch 2610-24-PWR, Switch 2610-48, Switch 2610-48-PWR, Switch 2910al-24G-PWR, Switch 2910al-48G-PWR , HPE 1700-24 Switch, 1810-24 v2, 1810-24G Switch, 1810-8 v2, 1910-8G Switch, 1910-8G-PoE+ (180W) Switch, 1910-8G-PoE+ (65W) Switch, 20p 10/100/1000 + 4p Mini-GBIC Module, 2610-24 Switch, 2610-24-PoE Switch, 2610-24-PPoE Switch, 2610-48 Switch, 2610-48-PoE Switch, 2810-24G Switch, 2810-48G Switch, 2910-24G al Switch, 2910-24G-PoE+ al Switch, 2910-48G al Switch, 2910-48G-PoE+ al Switch, 3500-24G-PoE yl Switch, 3500-48G-PoE yl Switch, 6120XG Blade Switch, 6200-24G-mGBIC yl Switch, 6600-24G, 6600-24G-4XG Switch, 6600-48G, 6600-48G-4XG Switch, Switch 1800-24G, Switch 2600-8-PWR, Switch 2626, Switch 2626-PWR, Switch 2650, Switch 2650-PWR, Switch 2824, Switch 2848, Switch 2900-24G, Switch 2900-48G, Switch 3400cl-24G, Switch 3400cl-48G, Switch 6108, Switch 8212zl, Switch fl 10-Port Mini-GBIC Interface Module, Switch gl 10/100/1000 Module, Switch gl Mini-GBIC Module, Switch vl 4-port Mini-GBIC Module, Switch XL 10/100/1000 Module, Switch xl Mini-GBIC Module, V1400-24G Switch, vl 20p Gig-T+ 4P SFP module switch
Scroll to top
