BT.com
Wishlist
HPE HP SC11Xe Sngl Chn PCI Exp HBA
Delivery
Standard Due date unavailable
The HP SC11Xe Host Bus Adapter provides customers with the flexibility and speed they have come to expect from HP. This HBA is ideal for HP tape customers needing to attach Ultra320 tape backup devices on servers using the PCI-Express interface, and provides support for Ultra 320 SCSI, Wide Ultra3 SCSI, and Wide Ultra2 SCSI protocols. It is the primary building block for SCSI backup solutions that provide the maximum of 320 MB/second bandwidth, twice the speed of previous-generation SCSI adapters.
HPE SC11Xe Host Bus Adapter - storage controller - Ultra320 SCSI - PCIe x4
Storage controller - plug-in card
Bus Type
PCIe x4
Ultra320 SCSI
Data Transfer Rate
320 MBps
Supported Devices
Tape drive
Channel Qty
1
Novell NetWare 6, Microsoft Windows Server 2003 Enterprise Edition, Microsoft Windows Server 2003 Standard Edition, Novell NetWare 6.5, SuSE Linux Enterprise Server 8 for AMD64, Red Hat Enterprise Linux ES 3 for Intel x86, SuSE Linux Enterprise Server 8 for Intel x86, SuSE Linux Enterprise Server 9 for x86/AMD64/Intel EM64T, Red Hat Enterprise Linux ES 3 for AMD64/EM64T, Red Hat Enterprise Linux ES 4 for Intel x86/ AMD64/ EM64T, Microsoft Windows Server 2003 Enterprise x64 Edition
1 year warranty
ProLiant DL120 G6, DL120 G7, DL160 G6, DL160 Gen8, DL165 G7, DL170h G6, DL180 G6, DL320 G6, DL360 G6, DL360 G7, DL360p Gen8, DL370 G6, DL380 G6, DL380 G7, DL385 G6, DL385 G7, DL385p Gen8, DL580 G7, DL585 G6, DL585 G7, DL785 G6, ML110 G6, ML110 G7, ML115 G5, ML310e Gen8, ML330 G6, ML350e Gen8
Host Bus
PCIe x4
Storage Controller
Ultra320 SCSI
Data Transfer Rate
320 MBps
Supported Devices
Tape drive
Channel Qty
1
1 x Ultra320 SCSI (LVD) - 68 PIN VHDCI (Mini-Centronics) (external) , 1 x - 68 pin HD D-Sub (HD-68) (internal)
Compatible Slots
1 x PCI Express x4
Limited warranty - parts - 1 year
HPE ProLiant DL120 G6, DL120 G6 Base, DL120 G6 Performance, DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL160 G6, DL160 G6 Special Server, DL160 Gen8, DL160 Gen8 Entry, DL160 Gen8 Performance, DL165 G5 Special Server, DL165 G7, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Performance, DL165 G7 Special Server, DL170h G6, DL180 G6, DL180 G6 Special Server, DL185 G5 Special Server, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL365 G5 Base, DL365 G5 High Efficiency, DL365 G5 Performance, DL370 G6 Base, DL370 G6 High Performance, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL385 G5 Entry, DL385 G5p Base, DL385 G5p High Performance, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G6, DL585 G6 Base, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G6, DL785 G6 Base, DL785 G6 Performance, ML110 G6, ML110 G7, ML110 G7 Base, ML110 G7 Entry, ML110 G7 Performance, ML115 G5 Special Server, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML310e Gen8, ML310e Gen8 Base, ML310e Gen8 Entry, ML310e Gen8 Performance, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350e Gen8 v2
Scroll to top
