BT.com
Wishlist
HPE HP R5KVA UPS 3U IEC309-32A HV Intl Kit
Delivery
Standard 1-3 working days
Looking for cost-effective power protection for your small office environments? HP Line Interactive Single Phase Uninterruptible Power System (UPS) solutions range from tower-based systems designed to safeguard tower servers and small office equipment, to rack-based systems that can protect a full rack of servers. Standard features include intuitive front panel displays for local management, hot-swappable battery modules, and HP Enhance Battery Management (EBM) that help to extend the service-life of your batteries. HP Power Protection, a power management software application that ships with each model, combined with a UPS Network Module, optional on some models, enables you to remotely monitor and manage your UPS through HP Systems Insight Manager or via a standard web browser. Backed by a 3-year limited warranty, HP's exclusive 30-day Battery Pre-Failure Warning provides notification of an impending battery failure and free battery replacement while under the warranty.
HPE UPS R5000 - UPS - 4.5 kW - 5000 VA
UPS - rack-mountable
Rack Size
3U
57 kg
Input Voltage
AC 220/230/240 V
Output Voltage
+ 6% / - 10%
Power Capacity
4.5 kW / 5000 VA
Input Connectors
1 x power IEC 60309 32A
Output connectors
4 x power IEC 60320 C19 , 4 x power IEC 60320 C13 , 1 x power IEC 60309 32A
Lead Acid expandable
Run Time (Up To)
5.7 min at full load
43.7 cm x 74.4 cm x 12.7 cm
HPE 600, 800; 11000 G2 Series; Advanced Series Racks 42U 600; Apollo 4510 Gen9; ProLiant c3000, DL120 Gen9, DL160 Gen9, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360 Gen9, DL360p Gen8, DL380 Gen9, DL60 Gen9, DL80 Gen9, e2000 G6, ML10 v2, ML110 Gen9, ML150 Gen9, ML350 Gen9, ML350p Gen8; Rack
Height (Rack Units)
3U
Input Voltage
AC 220/230/240 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
+ 6% / - 10%
Power Capacity
4.5 kW / 5000 VA
Output Waveform
Sinewave
Expandable
Lead Acid
Run Time (Up To)
Recharge Time
48 hours
Power cable - 3 m
Rack Mounting Kit
Included
Equipment Protection Value
250000 US Dollars
FCC Class A certified, C-Tick, BSMI, GOST, GS, UL 1778, EN 50091-2, IEC 62040-1-1, CSA C22.2, EN 50091-1, FCC CFR47 Part 15, UL 60950-1, EN 60950-1
Software Included
Drivers & Utilities
10 °C
20 - 80% (non-condensing)
Sound Emission
45 dB
43.7 cm
74.4 cm
12.7 cm
57 kg
Shipping Width
60 cm
Shipping Depth
98.5 cm
Shipping Height
36.6 cm
Shipping Weight
87 kg
HPE 600mm x 1075mm Advanced Pallet Rack, 600mm x 1075mm Advanced Shock Rack, 600mm x 1075mm Enterprise Crate Rack, 600mm x 1075mm Enterprise Pallet Rack, 600mm x 1075mm Enterprise Shock Rack, 600mm x 1200mm Advanced Pallet Rack, 600mm x 1200mm Advanced Shock Rack, 600mm x 1200mm Enterprise Air Duct Rack, 600mm x 1200mm Enterprise Pallet Rack, 600mm x 1200mm Enterprise Shock Network Rack, 600mm x 1200mm Enterprise Shock Rack, 600mm x 1200mm Grey Enterprise Air Duct Rack, 600mm x 1200mm Grey Enterprise Shock Rack, 600mm x 1200mm Network Advanced Shock Rack, 800mm x 1075mm Enterprise Pallet Rack, 800mm x 1075mm Enterprise Shock Rack, 800mm x 1200mm Advanced Pallet Rack, 800mm x 1200mm Advanced Shock Rack, 800mm x 1200mm Enterprise Pallet Rack, 800mm x 1200mm Enterprise Shock Network Rack, 800mm x 1200mm Enterprise Shock Rack, 800mm x 1200mm Grey Enterprise Shock Network Rack, 800mm x 1200mm Grey Enterprise Shock Rack, 800mm x 1200mm Network Advanced Shock Rack , HPE 11000 G2 Series 11642 1075mm Pallet Universal Rack , HPE Advanced Series Racks 42U 600mm x 1075mm Kitted Advanced Pallet Rack with Side Panels and Baying, 42U 600mm x 1075mm Kitted Advanced Shock Rack with Side Panels and Baying , HPE Apollo 4510 Gen9 , HPE ProLiant c3000, DL120 Gen9, DL120 Gen9 Entry, DL160 Gen9 Base, DL160 Gen9 Entry, DL160 Gen9 Performance, DL180 Gen9 Entry, DL180 Gen9 Storage, DL20 Gen9, DL20 Gen9 Entry, DL20 Gen9 Performance, DL320e Gen8 v2 Entry, DL360 Gen9 Performance, DL360p Gen8, DL360p Gen8 CMS, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL60 Gen9, DL60 Gen9 Base, DL60 Gen9 Entry, DL80 Gen9, DL80 Gen9 Base, DL80 Gen9 Entry, e2000 G6, ML10 v2, ML10 v2 Base, ML10 v2 Entry, ML10 v2 Performance, ML110 Gen9, ML110 Gen9 Base, ML110 Gen9 Entry, ML150 Gen9, ML150 Gen9 Base, ML150 Gen9 Entry, ML150 Gen9 Performance, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance, ML350p Gen8 , HPE Rack
Accessories
C2G .45m USB to DB9 Serial Adapter Cable
Quicklinx: 63MC | In Stock
£15.15
C2G 2M DB9 M/F ALL LINES EXT CBL BLK
Quicklinx: 63SX | In Stock
£4.53
C2G 10m DB9 M/F Extension Cable Black
Quicklinx: 660Z | In Stock
£11.13
C2G 5m DB9 M/F Extension Cable - Black
Quicklinx: 681X | In Stock
£7.39
C2G 7m DB9 M/F Extension Cable - Black
Quicklinx: 681Y | In Stock
£9.69
C2G DB9 M/F Null Modem Adapter
Quicklinx: 6841 | In Stock
£5.44
Scroll to top
