BT.com
Wishlist
HPE HP PS1810-8G Switch
£130.47
17 in stock
£130.47
Add to wishlist
Delivery
Standard 1-3 working days
The HPE PS1810 Switch Series is designed for small businesses looking for an integrated, easy-to-administer switch that complements the HPE ProLiant Gen8 and Gen9 Servers. Part of the HPE OfficeConnect portfolio, the series includes both 8- and 24-port Gigabit Layer 2 models. The switch series has a built in ability to auto-discover and monitor health status of HPE ProLiant Servers. Both models have a fanless design, making them ideal for office deployments. The 8-port model has an innovative design that allows it to be stacked on the HPE ProLiant MicroServer Gen8 platform.
HPE PS1810-8G Switch - switch - 8 ports - Managed
Switch - 8 ports - Managed
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Throughput: 11.9 Mpps , Switching capacity: 16 Gbps
MAC addresses: 8000
MAC Address Table Size
8000 entries
Jumbo Frame Support
9220 bytes
Remote Management Protocol
SNMP 1, SNMP 2c, HTTPS
Flow control, full duplex capability, DHCP support, power over Ethernet (PoE), BOOTP support, VLAN support, auto-uplink (auto MDI/MDI-X), DoS attack prevention, port mirroring, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Quality of Service (QoS), Jumbo Frames support, LLDP support, dual firmware images, link aggregation trunking, packet storm protection, security lock slot (cable lock sold separately)
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1t, IEEE 802.1ab (LLDP), IEEE 802.3az
23 cm x 24.5 cm x 4.39 cm
1.23 kg
Bundled Services
Enclosure Type
Desktop, wall-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
MAC addresses: 8000
8000 entries
Jumbo Frame Support
9220 bytes
Encryption Algorithm
SSL
RAM
128 MB
Flash Memory
8 MB
8 x 1000Base-T - RJ-45
Internal power supply
FCC Class A certified, CISPR 22 Class A, EN 60950, EN 61000-3-2, IEC 61000-4-8, IEC 60950, EN 61000-3-3, EN55022 Class A, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EN 61000-4-5, EN 61000-4-11, UL 60950-1, FCC CFR47 Part 15 B, VCCI V-3, VCCI V-4
23 cm
24.5 cm
4.39 cm
1.23 kg
Limited warranty - lifetime - response time: next business day
15 - 95%
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
15 - 95%
Accessories
£5.11
£3.88
£12.50
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.92
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£56.55
Scroll to top
