BT.com
Wishlist
HPE HP PS110 Wireless 11n VPN WW Router
HPE HP PS110 Wireless 11n VPN WW...
£142.47
£142.47
Add to wishlist
Delivery
Standard Due date unavailable
The HP PS110 Wireless 11n VPN Router Series is an ideal all-in-one solution for small businesses, purpose built to work with HP ProLiant Gen9 and Gen8 Servers. This business-class router includes a 4-port Gigabit Ethernet switch, an 802.11n Access Point for wireless connectivity, Gigabit Ethernet WAN interface for Internet connectivity and robust security features like SPI firewall and VPN technology to safeguard your organization. It features auto-discovery and monitoring of the HP ProLiant Server families and its innovative design allows it to be stacked on the HP ProLiant MicroServer Gen8.
HPE PS110 (WW) - wireless router - 802.11a/b/g/n - desktop, wall-mountable
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop, wall-mountable
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Performance
VPN throughput: 30 Mbps , NAT throughput: 920 Mbps
IPSec VPN tunnels: 5 , Concurrent sessions: 5 , VLANs supported: 4
Network / Transport Protocol
PPTP, L2TP, NTP, IPSec, ARP, DHCP
Routing Protocol
RIP-1, RIP-2, IGMP, static IPv4 routing, static IPv6 routing, RIPng
Remote Management Protocol
SNMP 1, SNMP 2c, HTTPS
Firewall protection, Layer 2 switching, DHCP support, NAT support, VPN support, IGMP snooping, traffic shaping, DoS attack prevention, content filtering, manageable, E-mail alert, MAC address filtering, IPv6 support, VPN passthrough, Wireless Distribution System (WDS) support, URL filtering, IP address filtering, MIMO technology, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), Multiple SSID support, IPv4 support, fanless, Network Access Control (NAC), DiffServ Code Point (DSCP) support, Wi-Fi Protected Setup (WPS v2), traffic remarking
IEEE 802.3, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.1w, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, Wi-Fi Protected Setup
AC 120/230 V
23 cm x 23.7 cm x 4.25 cm
1 kg
3 years warranty
ProLiant MicroServer Gen8 Performance
Enclosure Type
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Performance
MAC Address Table Size
2048 entries
Routing Protocol
Encryption Algorithm
WPA, WPA2
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.1w, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11e, IEEE 802.11n, Wi-Fi Protected Setup, UL 60950-1, EN 60950-1, CAN/CSA C22.2 No. 60950-1
1 x MIPS 700 MHz
Flash Memory
128 MB
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45
AC 120/230 V
9.5 Watt
MTBF
51.54 years
Software Included
HP Intelligent Management Center
23 cm
23.7 cm
4.25 cm
1 kg
Limited warranty - advance hardware replacement - 3 years - response time: next business day , Technical support - phone consulting - 3 years
5 - 95% (non-condensing)
HPE ProLiant MicroServer Gen8 Performance
Scroll to top
