BT.com
Wishlist
HPE HP ProLiant Moonshot-4QSFP+ Uplink Module Kit
HPE HP ProLiant Moonshot-4QSFP+...
£2,799.22
£2,799.22
Add to wishlist
Delivery
Standard Due date unavailable
Do you want the freedom to simplify deployment with low-latency uplink connectivity? When you deploy your HP Moonshot 1500 Chassis, you have the ability to include up to two 4-port HP Moonshot-4QSFP+ Uplink Modules. Paired with the HP Moonshot-180G Switch Module, you have a modular system that can dramatically simplify your data center. By disaggregating the uplink module from the internal switch, you have greater flexibility to deploy your choice of external interconnect and to future-proof your investment. The Moonshot-4QSFP+ Uplink Module features a low-power, low-latency design with four 40 GbE QSFP+ ports. Each uplink module delivers 160 GbE of aggregate bandwidth to connect the HP Moonshot System to an external network.
HPE Moonshot 4QSFP+ Uplink Module Kit - expansion module
Expansion module
Ports
40 Gigabit QSFP+ x 4
24.96 cm x 13.71 cm x 5.64 cm
963 g
10 GigE, 40 Gigabit LAN
Data Transfer Rate
40 Gbps
Moonshot 1500, 180G Switch Module
Expansion module
Ports
Wired
Data Transfer Rate
40 Gbps
Status Indicators
Port status, link activity, module locator
4 - QSFP+ , 1 x management - RJ-45
UL 60950-1, EN 60950-1, RoHS, CAN/CSA C22.2 No. 60950-1, EMC Class A
24.96 cm
13.71 cm
5.64 cm
963 g
10 °C
35 °C
10 - 90% (non-condensing)
HPE Moonshot 1500, 180G Switch Module
Accessories
£13.41
£17.41
£22.12
Scroll to top
