BT.com
Wishlist
HPE HP ProLiant GBE2C Ethernet Kit
£1,668.70
£1,668.70
Add to wishlist
Delivery
Standard Due date unavailable
The HP GbE2c Layer 2/3 Ethernet Blade Switch provides a full set of Layer 2 switching and Layer 3 routing features, sixteen internal downlinks, five uplinks and two internal cross-connects in a single low cost blade switch. Four of the five uplinks can be either copper or fiber using optional SFP fiber modules. This switch dramatically reduces cabling, power and cooling requirements compared to external stand-alone switches, allowing you to realize the full benefits of the HP c-Class BladeSystem. The HP GbE2c Layer 2/3 Ethernet Blade Switch builds on the heritage of the GbE2 switch family by delivering on-going enhancements such as a new "industry standard" CLI, Layer 3 routing, high availability features and SFP Fiber uplink ports. Along with simplified management, wire-speed performance, redundant path capabilities and HP's world class service and support, the HP GbE2c Layer2/3 Ethernet Blade Switch remains the price/performance leader of all blade switches.
HPE GbE2c Layer2/3 Ethernet Blade Switch for c-Class BladeSystem - switch - 16 ports - Managed - plug-in module
Switch - 16 ports - Managed
Enclosure Type
Plug-in module
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000 + 4 x SFP + 5 x 10/100/1000
MAC Address Table Size
8K entries
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS
BOOTP support, IGMP snooping, store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ac, IEEE 802.1s, IEEE 802.3d
36.8 cm x 29 cm x 6 cm
2 kg
1 year warranty
HPE BLc3000 Enclosure; BLc7000 Enclosure; BLc7000 Single-Phase Enclosure; BLc7000 Three-Phase Enclosure; ProLiant BL460c, BL465c, BL480c, BL685c
Enclosure Type
Plug-in module
Subtype
Gigabit Ethernet
Compatible Slots
1 x Expansion Slot
Ports
8K entries
Authentication Method
RADIUS, TACACS, TACACS+, Secure Shell v.2 (SSH2)
RAM
128 MB - SDRAM
Flash Memory
16 MB Flash
5 x 1000Base-T - RJ-45 , 4 x SFP (mini-GBIC)
FCC Class A certified, VCCI Class A ITE, AS/NZ 3548 Class A, ICES-003 Class A
36.8 cm
29 cm
6 cm
2 kg
1 year warranty
Service & Support Details
Limited warranty - parts and labour - 1 year - on-site
5 - 95%
HPE BLc3000 Enclosure , HPE BLc7000 Enclosure , HPE BLc7000 Single-Phase Enclosure w/2 Power Supplies and 4 Fans w/8 Insight Control Environment Trial Licenses, w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE BLc7000 Three-Phase Enclosure w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE ProLiant BL460c, BL465c, BL480c, BL685c
Scroll to top
