BT.com
Wishlist
HPE HP ProLiant BL cClass V Conn 8Gb 20-port Fib Chann Mod Opt Kit
HPE HP ProLiant BL cClass V Conn...
£6,127.02
£6,127.02
Add to wishlist
Delivery
Standard Due date unavailable
The HP Virtual Connect 8Gb 20-port Fibre Channel Module for c-Class BladeSystem offers enhanced virtual connect capabilities, allowing up to 128 virtual machines running on the same physical server to access separate storage resources. Provisioned storage resource is associated directly to a specific virtual machine-even if the virtual server is re-allocated within the BladeSystem. Storage management of virtual machines is no longer limited by single, physical HBA on a server blade. SAN administrators can now manage virtual HBAs with the same methods and viewpoint of physical HBAs. Virtual Connect 8Gb 20-port Fibre Channel Module is the simplest, most flexible connection to your SAN fabrics. The HP Virtual Connect 8Gb 20-port Fibre Channel Module unravels server connections by cleanly separating the server enclosure from SAN, makes SAN fabrics easier to layout by reducing cables without adding switches to the domain, and allows you to change servers in just minutes, not days.
HPE Virtual Connect 8Gb 20-Port Fibre Channel Module - switch - 20 ports - plug-in module
Switch - 20 ports
Enclosure Type
Plug-in module
Subtype
Fibre Channel
Ports
20 x 8Gb Fibre Channel
Auto-negotiation, manageable
26.8 cm x 9.3 cm x 2.8 cm
1.27 kg
1 year warranty
Bundled Services
1 year warranty
BLc3000 Enclosure; BLc3000 Single-Phase Enclosure; BLc7000 Enclosure; BLc7000 Enclosure Model X; BLc7000 Single-Phase Enclosure; BLc7000 Three-Phase Enclosure; ProLiant c3000
Switch - 20 ports
Enclosure Type
Plug-in module
Subtype
Fibre Channel
Compatible Slots
1 x Expansion Slot
Ports
Fibre Channel
FC-AL, FC-AL-2, FC-FG, FC-FLA, FC-GS, FC-GS-2, FC-GS-3, FC-PH, FC-PH-2, FC-PH-3, FC-VI
Status Indicators
Port status, link activity, link OK, module locator
16 x 8Gb Fibre Channel - backplane , 4 x SFP+
36 Watt
TUV, VCCI, cUL, EN55022 Class A, AS/NZ 3548 Class A, UL 60950-1, EN 60950-1, WEEE, FCC Part 15 A, MIC Class A
26.8 cm
9.3 cm
2.8 cm
1.27 kg
Limited warranty - parts and labour - 1 year - on-site
10 °C
35 °C
10 - 90%
HPE BLc3000 Enclosure , HPE BLc3000 Single-Phase Enclosure , HPE BLc7000 Enclosure , HPE BLc7000 Enclosure Model X , HPE BLc7000 Single-Phase Enclosure , HPE BLc7000 Three-Phase Enclosure , HPE ProLiant c3000
Accessories
£13.78
£15.60
£20.24
£25.72
Scroll to top
