BT.com
Wishlist
HPE HP ProLaint Moonshot 6SFP Uplink Module Kit
HPE HP ProLaint Moonshot 6SFP...
£514.15
£514.15
Add to wishlist
Delivery
Standard Due date unavailable
Do you want the freedom to simplify deployment with low-latency uplink connectivity? When you deploy your HP Moonshot 1500 Chassis, you have the ability to include up to two 6-port HP Moonshot–6SFP Uplink Modules. Paired with the HP Moonshot–45G Switch Module, you have a modular system that can dramatically simplify your data center. By disaggregating the uplink module from the internal switch, you have greater flexibility to deploy your choice of external interconnect, and to future-proof your investment. The Moonshot-6SFP Uplink Module features a low-power, low-latency design with six 10 GbE SFP+ ports. Each uplink module delivers 60 GbE of aggregate bandwidth to connect the HP Moonshot system to an external network.
HPE Moonshot 6SFP Uplink Module Kit - expansion module - 6 ports
Expansion module
24.96 cm x 13.71 cm x 5.64 cm
1.39 kg
Ports Qty
6 ports
GigE, 10 GigE
Data Transfer Rate
10 Gbps
P/N: 700350-B21
Expansion module - 6 ports
Wired
GigE, 10 GigE
Data Transfer Rate
10 Gbps
6 x network - SFP/SFP+
Compatible Slots
Expansion Slot
24.96 cm
13.71 cm
5.64 cm
1.39 kg
P/N: 700350-B21
Accessories
£12.21
£13.81
£17.94
£22.80
Scroll to top
