BT.com
Wishlist
HPE HP ProCurve 10-GbE SFP+ LRM SFP+ Transceiver Module
HPE HP ProCurve 10-GbE SFP+ LRM...
£313.42
£313.42
Add to wishlist
Delivery
Standard Due date unavailable
A 10-Gigabit transceiver in SFP+ form-factor that supports the 10-Gigabit LRM standard, for 10-Gigabit connectivity up to 220 m on legacy multimode fiber.
HPE - SFP+ transceiver module - 10 Gigabit Ethernet
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-LRM
Optical Wave Length
1310 nm
10 Gigabit Ethernet
Max Transfer Distance
220 m
1.4 cm x 5.6 cm x 1.2 cm
Aruba 5406 zl; HP SFP+ zl Module Rack Shippable; HPE 2-Port SFP+/ 2-Port CX4 10GbE yl Module, 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch, SFP+ zl; Modular Smart Array P2000 G3 10GbE iSCSI Dual Controller SFF Array System, P2000 G3 iSCSI Dual Controller SFF Bundle
Plug-in module
Wired
Cabling Type
10GBase-LRM
10 Gigabit Ethernet
Optical Wave Length
1310 nm
220 m
IEEE 802.3aq
1 x Ethernet 10GBase-LRM - LC multi-mode
Compatible Slots
1 x SFP+
1.4 cm
5.6 cm
1.2 cm
70 °C
Aruba 5406 zl , HP SFP+ zl Module Rack Shippable , HPE 2-Port SFP+/ 2-Port CX4 10GbE yl Module, 6120XG Blade Switch, 6600-24G-4XG Switch, 6600-48G-4XG Switch, SFP+ zl , HPE Modular Smart Array P2000 G3 10GbE iSCSI Dual Controller SFF Array System, P2000 G3 iSCSI Dual Controller SFF Bundle
Scroll to top
