BT.com
Wishlist
HPE HP PL BLcCls c3000 RK Enc 4 Pwr Sup DVD LIC
Delivery
Standard Due date unavailable
The HP BladeSystem c3000 Platinum Enclosure brings new capabilities to HP BladeSystem. The c3000 targets three separate market segments: 1) remote sites needing between 2 and 8 server blades; 2) mid-sized companies with between 3 and 100 servers; and 3) enterprise accounts with special datacenter requirements, such as DC power, or very limited rack power and cooling capacity. Similar to the c7000, the Intelligent Management through the Onboard Administrator gives you complete control of your bladed infrastructure. A multi-terabit backplane ensures that the c3000 Enclosure can support today's Gigabit networks with an easy migration to tomorrow's 10 Gigabit solutions.
HPE BLc3000 Enclosure - rack-mountable - 6U
System cabinet
Rack-mountable - 6U
Installed Fans Qty
6
Power supply - hot-plug
48.5 cm x 83.5 cm x 26.5 cm
59 kg
3 years warranty
Integrity BL860c i2, BL870c i2, BL890c i2; ProLiant BL280c G6, BL460c G5, BL460c G6, BL460c G7, BL465c G6, BL465c G7, BL490c G6, BL490c G7, BL495c G5, BL495c G6, BL685c G6, BL685c G7, WS460c G6; StorageWorks SB1760; StorageWorks Network Storage Blade X1800; StorageWorks Network Storage Gateway X3800
Rack-mountable - 6U
Fans
Rear : 6 - ( 6 installed)
Expansion Slots
8 x Expansion Slot
Installed Qty
4
Max Supported Qty
6
48.5 cm
83.5 cm
26.5 cm
59 kg
Limited warranty - parts and labour - 3 years - on-site
10 °C
35 °C
10 - 90%
HPE Integrity BL860c, BL860c i2, BL860c i2 Base, BL870c, BL870c i2, BL890c i2 , HPE ProLiant BL260c G5, BL280c G6, BL2x220c G5, BL2x220c G5 Server A, BL2x220c G5 Server B, BL460c, BL460c G5, BL460c G6, BL460c G7, BL465c, BL465c G5, BL465c G6, BL465c G7, BL480c, BL490c G6, BL490c G7, BL495c G5, BL495c G6, BL680c G5, BL685c, BL685c G5, BL685c G6, BL685c G7, SB460c SAN Gateway Storage Server, WS460c G6 Workstation Blade, xw460c Blade Workstation , HPE StorageWorks SB1760c Tape Blade, SB40c storage blade , HPE StorageWorks All-in-One Storage System SB600c 1.16TB Storage Blade , HPE StorageWorks Network Storage Blade X1800sb , HPE StorageWorks Network Storage Gateway X3800sb , HPE StorageWorks Ultrium 448c Tape Blade, SB920c
Scroll to top
