BT.com
Wishlist
HPE HP PL BL CCLASS C7000 SNGL-PHASE ENCLOSURE
Delivery
Standard Due date unavailable
The BladeSystem c7000 enclosure provides all the power, cooling, and I/O infrastructure needed to support modular server, interconnect, and storage components today and throughout the next several years. The enclosure is 10U high and holds up to 16 server and/or storage blades plus optional redundant network and storage interconnect modules. It includes a shared 7.1 Tbps high-speed NonStop mid-plane for wire-once connectivity of server blades to network and shared storage. Power is delivered through a pooled-power backplane, and power input flexibility is provided with choices of single-phase AC input, 3-phase AC input, -48V DC input, and high voltage DC input.
HPE BLc7000 Single-Phase Enclosure w/2 Power Supplies and 4 Fans w/8 Insight Control Environment Trial Licenses - rack-mountable - 10U
System cabinet
Rack-mountable - 10U
Built-in Devices
Display
Power supply
Power Redundancy
AC 230V ( 50/60 Hz )
44.7 cm x 81.3 cm x 44.2 cm
87 kg
3 years warranty
Integrity BL860c i2, BL870c i2, BL890c i2; ProLiant BL2x220c G6, BL2x220c G7, BL460c G7, BL465c G6, BL465c G7, BL490c G7, BL495c G6, BL620C G7, BL680c G7, BL685c G6, BL685c G7, WS460c G6; StorageWorks SB1760; StorageWorks Network Storage Blade X1800; StorageWorks Network Storage Gateway X3800
Built-in Devices
Display
Fans
10 - ( 4 installed)
Expansion Slots
16 x Expansion Slot
RoHS
Power supply
Power Redundancy
Installed Qty
2
Max Supported Qty
6
Power Supply Features
Power Factor Correction (PFC)
44.7 cm
81.3 cm
44.2 cm
87 kg
3 years warranty
Service & Support Details
Limited warranty - parts and labour - 3 years - on-site
10 °C
35 °C
10 - 90%
HPE Integrity BL860c, BL860c i2, BL860c i2 Base, BL870c, BL870c i2, BL890c i2, BL890c i2 Base , HPE ProLiant BL260c G5, BL280c G6, BL2x220c G5, BL2x220c G5 Server A, BL2x220c G5 Server B, BL2x220c G6, BL2x220c G6 Server A, BL2x220c G6 Server B, BL2x220c G7, BL460c, BL460c G5, BL460c G6, BL460c G7, BL465c, BL465c G5, BL465c G6, BL465c G7, BL480c, BL490c G6, BL490c G7, BL495c G5, BL495c G6, BL620C G7, BL680c G5, BL680c G7, BL685c, BL685c G5, BL685c G6, BL685c G7, SB460c SAN Gateway Storage Server, WS460c G6 Workstation Blade, xw460c Blade Workstation , HPE StorageWorks SB1760c Tape Blade, SB40c storage blade , HPE StorageWorks All-in-One Storage System SB600c 1.16TB Storage Blade , HPE StorageWorks Network Storage Blade X1800sb , HPE StorageWorks Network Storage Gateway X3800sb , HPE StorageWorks Ultrium 448c Tape Blade, SB920c
Scroll to top
