Click to visit BT.com
BT.com
Wishlist
HPE HP NC550SFP DPt 10GbE Server Adpt
Quicklinx: 71F9WS00
Mfr#: 581201-B21
The NC550SFP is an eight lane (x8) PCI Express (PCIe) 10 Gigabit network solution offering optimal throughput for a ProLiant Ethernet adapter. This PCI Express Gen 2 adapter ships with two SFP+ (Small Form-factor Pluggable) cages suitable for connecting to Direct Attach Cable (DAC) or an SR fiber module supporting fiber optic cabling. The NC550SFP ships with advanced server features that ProLiant customers have come to expect, such as support for TCP checksum and segmentation, Large Send and Large Receive offload capability, VLAN tagging, 9K jumbo frames, IPv4 and IPv6, teaming for failover and load balancing, and TCP/IP Offload for Windows. Easy to install and configure, the NC550SFP can be used in either standard or low profile slots.
HPE NC550SFP - network adapter - 2 ports
Network adapter
Interface (Bus) Type
PCI Express 2.0 x8
PCI Specification Revision
PCIe 2.0
16.8 cm x 6.9 cm
Ports Qty
2 ports
10 GigE
1 ServerEngines
IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae, IEEE 802.3ap, IEEE 802.3az
SuSE Linux Enterprise Server, Microsoft Windows Server 2003 Enterprise Edition, Microsoft Windows Server 2003 Standard Edition, Red Hat Enterprise Linux, Microsoft Windows Server 2003 Standard x64 Edition, Microsoft Windows Server 2003 Enterprise x64 Edition, Microsoft Windows Server 2008
ProLiant DL160 G6, DL160se G6, DL165 G7, DL170h G6, DL180 G6, DL2x170h G6, DL320 G6, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL385 G6, DL385 G7, DL4x170h G6, DL580 G7, DL585 G6, DL585 G7, DL785 G6, DL980 G7, ML330 G6, SL160s G6, SL160z G6, SL165s G7, SL165z G6, SL165z G7, SL170z G6, SL2x170z G6
Network adapter - 2 ports
PCI Express 2.0 x8
PCIe 2.0
Wired
10 GigE
IPv6 support, TCP/IP offloading, Quality of Service (QoS), Jumbo Frames support
Processor / Memory
1 - ServerEngines
Expansion Slots
2 (total) / 2 (free) x SFP+
Low-profile bracket
16.8 cm
6.9 cm
55 °C
10 - 90%
HPE ProLiant DL160 G6, DL160 G6 Special Server, DL160se G6, DL165 G5, DL165 G5 Special Server, DL165 G7, DL165 G7 Base, DL165 G7 Performance, DL165 G7 Special Server, DL170h G6, DL180 G6, DL180 G6 Special Server, DL2x170h G6, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL370 G6, DL370 G6 Base, DL370 G6 Performance, DL370 G6 Special Server, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G6 Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 Performance, DL4x170h G6, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G5, DL585 G5 High Performance, DL585 G6, DL585 G6 Base, DL585 G6 Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G5, DL785 G6, DL785 G6 Base, DL785 G6 Performance, DL980 G7, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry, SL160s G6, SL160z G6, SL165s G7, SL165z G6, SL165z G7, SL170z G6, SL2x170z G6
