BT.com
Wishlist
HPE HP MSR930 4G LTE/3G WCDMA Global Router
HPE HP MSR930 4G LTE/3G WCDMA...
£579.74
£579.74
Add to wishlist
Delivery
Standard Due date unavailable
The HP MSR93x Router Series delivers a high-performance small-branch router providing integrated routing, switching, security, SIP, 802.11n WLAN connectivity, and 4G LTE/3G in a single unit. With its Converged Infrastructure, it enables faster time to service and enhanced performance while simplifying your network through a single management screen and zero-touch deployment. The MSR93x increases flexibility and agility, delivering extensive connectivity capabilities in a compact, fixed form factor. The MSR93x is based on open standards for seamless integration within small-branch deployment.
HPE MSR930 4G LTE/3G WCDMA Global Router - router - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
Cellular Protocol
WCDMA, LTE
Performance
Forwarding performance (64-byte packet size): 300 Kpps , Encryption throughput: 160 Mbps
VPN tunnels: 100 , IPv4 forwarding table entries: 10000 , IPv6 forwarding table entries: 5000
Network / Transport Protocol
TCP/IP, UDP/IP, L2TP, RSVP, APPN, NTP, ICMP/IP, IPSec, PPPoE, ARP, BOOTP, DHCP
Routing Protocol
OSPF, EGP, RIP, BGP-4, IS-IS, RIP-1, RIP-2, BGP, IGMPv2, IGMP, VRRP, IGMPv3, GRE, OSPFv3, MSDP, static IPv4 routing, static IPv6 routing, ECMP, RIPng, MLD, BGP-4+, CIDR
Remote Management Protocol
SNMP 1, SNMP 2, RMON, Telnet, SNMP 3, HTTP, TFTP, CLI
Firewall protection, Layer 2 switching, DHCP support, NAT support, VPN support, BOOTP support, ARP support, MPLS support, IGMP snooping, Syslog support, traffic shaping, port mirroring, IPv6 support, Weighted Fair Queuing (WFQ), Weighted Random Early Detection (WRED), sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, tunnelling, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Committed Access Rate (CAR), MLD snooping, Unicast Reverse Path Forwarding (URPF), IPv4 support, Management Information Base (MIB), loop prevention, port isolation, packet storm protection, Class of Service (CoS), Loopback, IGMP proxy, Dynamic Virtual Private Network (DVPN), Network Quality Analyzer (NQA), Multicast Border Gateway Protocol (MBGP), WWAN support, Type of Service (ToS)
IEEE 802.2, IEEE 802.3, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
23 cm x 16 cm x 4.36 cm
1.8 kg
Enclosure Type
Desktop
Wireless, wired
Performance
Routing Protocol
Encryption Algorithm
MD5, AES, IKE, TLS
Authentication Method
RADIUS, PAP, CHAP, TACACS+, Secure Shell v.2 (SSH2), Extensible Authentication Protocol (EAP)
IEEE 802.2, IEEE 802.3, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, EN55024, EN55022 Class B, ICES-003 Class B, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EMC, EN 61000-4-5, EN 61000-4-11, RoHS, EN300-386, EN 61000-4-8, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, FDA, FCC CFR47 Part 15 B, EN 60825-1, CAN/CSA C22.2 No. 60950-1, AS/NZS 60950, ANSI C63.4, EN 60825-2, CAN/CSA C22.2 No. 60950-1-03, EN 61000-3-2:2006, EN 61000-3-3:1995+A1:2001+A2:2005
1 x 533 MHz
RAM
256 MB DDR SDRAM
Flash Memory
128 MB
Communications
Cellular Protocol
WCDMA, LTE
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Antenna: 1 x GPS connector , Antenna: 1 x
Aerial
Aerial
External integrated and internal
Antenna Qty
2
External power adapter
23 cm
16 cm
4.36 cm
1.8 kg
5 - 90% (non-condensing)
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.86
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.56
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£22.75
£15.85
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.50
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£21.84
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£40.51
£42.69
Scroll to top
