BT.com
Wishlist
HPE HP M210 802.11n Access Point (WW)
Delivery
Standard Due date unavailable
Ideal for small businesses, the cost-effective HPE M210 802.11n Access Point Series, supports standalone operation or can be "clustered" for simplified administration of up to 4 access points where more robust coverage is required. These dual-band, single-radio devices support high-speed wireless networking at 5GHz or 2.4GHz to provide a better user experience and faster delivery of mobile applications. Clustering technology propagates wireless network configurations across all access points for consistent security and uninterrupted, wireless client roaming.
HPE M210 (WW) - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Maximum number of configured SSIDs: 4 , VLANs supported: 4
Power Over Ethernet (PoE) Supported
PoE
19.35 cm x 12.7 cm x 3.81 cm
340 g
Radio access point
19.35 cm
12.7 cm
3.81 cm
340 g
External
Wireless
Data Transfer Rate
300 Mbps
Remote Management Protocol
HTTP, HTTPS
Communication Mode
Half-duplex, full-duplex
Frequency Band
2.4 GHz, 5 GHz
Auto-uplink (auto MDI/MDI-X), IPv6 support, Wireless Distribution System (WDS) support, MIMO technology, Spanning Tree Protocol (STP) support
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, SSL, TKIP, WPA, WPA2
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
2
1 x 1000Base-T - RJ-45
IEC 60950-1 Second Edition, EN 300 328, EN 50385
PoE
Limited warranty - lifetime
15 - 95% (non-condensing)
Accessories
£4.95
£3.84
£11.41
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.16
£51.70
Scroll to top
