BT.com
Wishlist
HPE HP LTO-1 Ultrium Automation Bar Code Labels
Delivery
Standard Due date unavailable
HPE LTO Ultrium, Super DLT and DLTtape IV Bar Code Label Packs provide an easy-to-use solution to the aggravation of bar coding. Under constant pressure to deliver quality of service with limited resources, the last thing IT managers should be worrying about is why their in-house bar code labels aren't working properly or whose turn it is to operate (or run) the departmental label printer. Each HPE label pack of consecutively numbered bar codes contains 100 data labels and 10 cleaning cartridge labels. No two pack sequences are ever identical to avoid data integrity issues in archives. HPE Bar Code Label Packs will be available from most resellers that stock HPE brand media. Finally, HPE Bar Code Label Packs have been fully tested to guarantee performance in demanding automation environments, so unlike cheaper alternatives, users can be certain that their backups will never be disrupted by bar code quality issues.
HPE Ultrium 1 Bar Code Label Pack - bar code labels
Bar code labels
StorageWorks MSL5030, MSL5060; StorageWorks 1/8 G2 Tape Autoloader Ultrium 448; StorageWorks Ultrium 460; SureStore Ultrium 230, 230e, 230i
Bar code labels
HPE StorageWorks MSL5030, MSL5060 , HPE StorageWorks 1/8 G2 Tape Autoloader Ultrium 448 , HPE StorageWorks Ultrium 460 , HPE SureStore Ultrium 230, 230e, 230i
Scroll to top
