BT.com
Wishlist
HPE HP InfiniBand 4X DDR ConnectX-2 PCIe G2 Dual Port HCA Net Adapt
HPE HP InfiniBand 4X DDR ConnectX-2...
£1,072.72
£1,072.72
Add to wishlist
Delivery
Standard Due date unavailable
The next generation of HP InfiniBand Adapters for select HP ProLiant BLc, DL, ML, SL, and XL servers, Gen8 and Gen9 models. Based on Mellanox ConnectX-3 Pro technology for unprecedented scalability and fabric flexibility, they are all dual ported and can function as a dual ported InfiniBand card, a dual ported Ethernet card, or a mixed function card in rack servers. Combined with HP InfiniBand FDR edge switches, they deliver low-latency InfiniBand bandwidth, up to 56 Gb/s Fourteen Data Rate (FDR) or up to 40 Gb/s Quad Data Rate (QDR), for performance driven server and storage clustering applications in High Performance Computing (HPC) and enterprise data centers.
HPE InfiniBand 4X DDR CX-2 PCI-e G2 Dual-port HCA - network adapter - 2 ports
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express 2.0 x8
PCI Specification Revision
PCIe 2.0
Ports Qty
2 ports
Cabling Type
4x InfiniBand (SFF-8470)
InfiniBand
Data Transfer Rate
40 Gbps
ProLiant DL160 G6, DL160se G6, DL180 G6, DL360 G6, DL360 G7, DL370 G6, DL380 G6, DL380 G7, DL580 G7, DL585 G7, DL980 G7, ML370 G6, SL160s G6, SL160z G6, SL165s G7, SL170z G6, SL2x170z G6
Network adapter - 2 ports
Plug-in card
PCI Express 2.0 x8
PCIe 2.0
Wired
Cabling Type
InfiniBand
Data Transfer Rate
40 Gbps
InfiniBand QDR Link support
2 x InfiniBand - 4x InfiniBand (SFF-8470)
Compatible Slots
1 x PCI Express 2.0 x8
HPE ProLiant DL160 G6, DL160 G6 Special Server, DL160se G6, DL180 G6, DL180 G6 Special Server, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 G7, DL360 G7 Base, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL370 G6 Special Server, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL980 G7, ML370 G6 Special Server, SL160s G6, SL160z G6, SL165s G7, SL170z G6, SL2x170z G6
Scroll to top
