BT.com
Wishlist
HPE HP IEEE 1394b FireWire PCIe Card
HPE HP IEEE 1394b FireWire PCIe...
£79.38
£79.38
Add to wishlist
Delivery
Standard Due date unavailable
This high speed serial interface enables fast data transfer from external peripherals such as external hard disks, digital cameras and video cameras. Twice the transfer rate of IEEE-1394a cards, it features two external ports and one internal header. IEEE-1394b is one of the fastest serial interface standards ever developed which makes it great for use with high-speed or bandwidth-intensive multimedia peripherals such as digital video cameras, audio, streaming and graphics.
The HP IEEE-1394b FireWire 800 PCIe card is backward compatible to allow your IEEE-1394a devices to operate under the IEEE-1394b port with the use of a 1394a-to-1394b adapter cable.
The PCIe card features two external IEEE-1394b ports located on the PCIe card bracket and one internal port header located on the PCIe card to connect to front panel 1394a port on HP Workstations.
HP - FireWire adapter - 3 ports
FireWire adapter
Plug-in card
Interface (Bus) Type
PCI Express
Ports Qty
3 ports
FireWire 800
Data Transfer Rate
800 Mbps
Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Vista
Workstation xw9400, Z220, Z230, z400, Z420, Z620, z800, Z820; Workstation z600
Plug-in card
PCI Express
Wired
FireWire 800
Data Transfer Rate
800 Mbps
2 x FireWire 800 - 9 pin FireWire 800 (external) , 1 x FireWire 800 (internal)
Compatible Slots
1 x PCI Express
BSMI, FCC Part 15 B, MIC
System Requirements Details
Pentium III RAM 128 MB - HD 1 GB
10 °C
55 °C
20 - 80%
HP Workstation xw9400, Z220, Z230, z400, Z420, Z620, z800, Z820 , HPE Workstation z600
Scroll to top
