BT.com
Wishlist
HPE HP HPE 8GB 2Rx8 PC4-2133P-E-15 Standard Kit
HPE HP HPE 8GB 2Rx8 PC4-2133P-E-15...
£103.36
19 in stock
£103.36
Add to wishlist
Delivery
Standard 1-3 working days
Do you need to increase the main memory in your HPE entry-level ProLiant Gen9 Servers? The HPE Standard Memory options are designed for the HPE entry-level servers delivering an excellent combination of pricing, quality, reliability, performance and compatibility compared to third-party alternatives.
HPE - DDR4 - 8 GB - DIMM 288-pin
RAM memory
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz ( PC4-17000 )
Latency Timings
CL15 ( 15-15-15 )
Dual rank , unbuffered
Voltage
1.2 V
HP 805669-B21
ProLiant DL20 Gen9, ML10 Gen9, ML10 Gen9 Entry, ML10 Gen9 Performance, ML30 Gen9
8 GB
Upgrade Type
System specific
HP 805669-B21
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15 ( 15-15-15 )
ECC
Chips Organization
X8
Voltage
1.2 V
Colour Category
Green
HPE ProLiant DL20 Gen9, ML10 Gen9, ML10 Gen9 Entry, ML10 Gen9 Performance, ML30 Gen9
£103.36
Save on this ideal PC Build kit!
Save £9.25
£122.92
Scroll to top
