BT.com
Wishlist
HPE HP HP UPS Network Module MINI-SLOT Kit
HPE HP HP UPS Network Module...
£187.71
£187.71
Add to wishlist
Delivery
Standard Due date unavailable
The HP UPS network module allows an HP Uninterruptible Power System (UPS) to be directly connected to the network for remote monitoring and management of either a single UPS, or two UPSs in a redundant configuration. The UPS network module works with the HP power protector clients and can be configured to send alert traps to HP systems insight manager and other SNMP management programs or used as a standalone management system. This flexibility enables you to monitor and manage UPSs through the network. To facilitate day-to-day maintenance tasks, the embedded management software provides detailed system logs.
The HP UPS network module enables you to configure, monitor and manage power environments through comprehensive control of individual HP UPSs.
The UPS network module can be configured to send alert traps to HP systems insight manager and other SNMP management programs or used as a standalone management system. This flexibility enables you to monitor and manage the UPS through the network connector; the serial connector located on the front of the management module is only used for configuration. To facilitate day-to-day maintenance tasks, the firmware provides detailed system logs.
HPE UPS Network Module MINI-SLOT Kit - remote management adapter
Remote management adapter
Plug-in module
13 cm x 4 cm x 6 cm
460 g
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
3 years warranty
ProLiant ML110 G6, ML110 G7, ML150 G6, ML330 G6, ML350 G6, ML350 G6 Base, ML350 G6 Performance, ML350 G6 Special Server; Rack
Plug-in module
Wired
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Remote Management Protocol
SNMP, HTTP
128-bit encryption
1 - RJ-45 , 1 x management
Compatible Slots
1 x Expansion Slot
1 x serial adapter
Encryption Algorithm
128-bit SSL
13 cm
4 cm
6 cm
460 g
Limited warranty - 3 years
10 °C
20 - 80% (non-condensing)
HPE ProLiant ML110 G6, ML110 G7, ML150 G6, ML330 G6, ML350 G6, ML350 G6 Base, ML350 G6 Performance, ML350 G6 Special Server , HPE Rack
Accessories
£5.16
£3.90
£12.61
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.01
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£57.07
Scroll to top
