BT.com
Wishlist
HPE HP HP STORAGEWORKS 1U SAS RACK MOUNT KIT
HPE HP HP STORAGEWORKS 1U SAS RACK...
£342.43
£342.43
Add to wishlist
Delivery
Standard 1-3 working days
The HP Rack-mount Kits provide a high density, rack-mountable tape drive and RDX removable disk drive solution for both direct-attach SCSI, USB, or SAS backup and archiving applications. The HP 1U Rack-mount Kit supports DAT and LTO Ultrium internal tape drives, and RDX internal removable disk backup systems. The 1U rack-mount kit is available in SCSI, SAS and USB interfaces. With two LTO-6 Ultrium 6250 drives, the 1U SAS enclosure can provide a maximum compressed capacity of 12.5TB with a data transfer rate up to 2.8TB/hr. The HP 3U Rack-mount Kit holds two (2) full-height internal tape drives, four half-height internal tape drives, or a combination of one full height and two half-height tape drives. It is available in both SCSI and SAS interfaces. With four LTO-6 Ultrium 6250 SAS drives this enclosure solution can provide a maximum compressed capacity of 25TB.
HPE StorageWorks SAS Rack-Mount Kit - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 1U
42.9 cm x 64.1 cm x 4.3 cm
8.1 kg
LTO-4 Ultrium; LTO-5 Ultrium; ProLiant DL360p Gen8, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special; StorageWorks LTO-5 Ultrium; StorageWorks Rack-Mount Kit Ultrium 1760 Drive; StorageWorks Ultrium 1760; Ultrium 448, 920
Storage enclosure
Enclosure Type
Rack-mountable - 1U
Enclosure Colour
Carbon
2 x SAS 6Gb/s
Internal power supply
42.9 cm
64.1 cm
4.3 cm
8.1 kg
5 °C
20 - 80%
HPE LTO-4 Ultrium 1760 , HPE LTO-5 Ultrium 3000, 3000 SAS Internal Tape Drive , HPE ProLiant DL360p Gen8, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special , HPE StorageWorks LTO-5 Ultrium 3000 SAS Internal Tape Drive , HPE StorageWorks Rack-Mount Kit Ultrium 1760 Drive , HPE StorageWorks Ultrium 1760 , HPE Ultrium 448, 920
Scroll to top
