BT.com
Wishlist
HPE HP HP 1.8TB 12G SAS 10K 2.5" SC 512e HDD
HPE HP HP 1.8TB 12G SAS 10K 2.5" SC...
£459.50
15 in stock
£459.50
Add to wishlist
Delivery
Standard 1-3 working days
Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
HPE Enterprise - hard drive - 1.8 TB - SAS 12Gb/s
Hard drive - hot-swap
1.8 TB
2.5" SFF
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Spindle Speed
10000 rpm
Advanced format 512e
75.7 mm x 118.7 mm x 15.6 mm
3 years warranty
Bundled with
HP SmartDrive carrier
ProLiant BL420c Gen8, BL460c Gen8, BL465c Gen8, BL660c Gen8, BL660c Gen9, DL160 Gen8, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360 Gen9, DL360e Gen8, DL380p Gen8, DL385p Gen8, DL560 Gen9, DL580 Gen8, DL580 Gen9, ML110 Gen9, ML150 Gen9, ML30 Gen9, ML350 Gen9, ML350e Gen8, WS460c Gen8, WS460c Gen9, XL250a Gen9
1.8 TB
2.5" SFF
SAS 12Gb/s
Bytes per Sector
512
75.7 mm
118.7 mm
15.6 mm
Bundled with
Performance
Drive Transfer Rate
1.2 GBps (external)
Seek Time
3.7 ms (average) / 7.3 ms (max)
Track-to-Track Seek Time
0.1 ms
Spindle Speed
10000 rpm
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
2.5" SFF
Limited warranty - 3 years
10 °C
35 °C
HPE ProLiant BL420c Gen8 (2.5"), BL460c Gen8 (2.5"), BL465c Gen8 (2.5"), BL660c Gen8 (2.5"), BL660c Gen8 Entry (2.5"), BL660c Gen8 Performance (2.5"), BL660c Gen9 (2.5"), DL180 Gen9 (2.5"), DL180 Gen9 Base (2.5"), DL180 Gen9 Entry (2.5"), DL180 Gen9 Storage (2.5"), DL20 Gen9 (2.5"), DL20 Gen9 Entry (2.5"), DL20 Gen9 Performance (2.5"), DL320e Gen8 (2.5"), DL320e Gen8 Base (2.5"), DL320e Gen8 Entry (2.5"), DL320e Gen8 Performance (2.5"), DL320e Gen8 Special Server (2.5"), DL320e Gen8 v2 (2.5"), DL320e Gen8 v2 Base (2.5"), DL320e Gen8 v2 Entry (2.5"), DL320e Gen8 v2 Performance (2.5"), DL360 Gen9 (2.5"), DL360 Gen9 Base (2.5"), DL360 Gen9 CMS (2.5"), DL360 Gen9 Entry (2.5"), DL360 Gen9 Performance (2.5"), DL360e Gen8 (2.5"), DL360e Gen8 Base (2.5"), DL360e Gen8 Entry (2.5"), DL360e Gen8 Performance (2.5"), DL360e Gen8 Special Server (2.5"), DL380p Gen8 Performance (2.5"), DL380p Gen8 Special (2.5"), DL385p Gen8 (2.5"), DL385p Gen8 Dedicated Workload (2.5"), DL385p Gen8 Entry (2.5"), DL385p Gen8 Maximized Consolidation (2.5"), DL385p Gen8 Storage (2.5"), DL385p Gen8 Storage Centric (2.5"), DL560 Gen9 (2.5"), DL560 Gen9 Base (2.5"), DL560 Gen9 Entry (2.5"), DL560 Gen9 Performance (2.5"), DL580 Gen8 (2.5"), DL580 Gen8 Base (2.5"), DL580 Gen8 High Performance (2.5"), DL580 Gen9 (2.5"), DL580 Gen9 Database (2.5"), ML110 Gen9 (2.5"), ML110 Gen9 Base (2.5"), ML110 Gen9 Entry (2.5"), ML150 Gen9 (2.5"), ML150 Gen9 Base (2.5"), ML150 Gen9 Entry (2.5"), ML150 Gen9 Performance (2.5"), ML30 Gen9 (2.5"), ML30 Gen9 Base (2.5"), ML30 Gen9 Performance (2.5"), ML350 Gen9 (2.5"), ML350 Gen9 Base (2.5"), ML350 Gen9 Entry (2.5"), ML350 Gen9 Performance (2.5"), ML350e Gen8 (2.5"), ML350e Gen8 v2 (2.5"), ML350e Gen8 v2 Base (2.5"), ML350e Gen8 v2 Entry (2.5"), WS460c Gen8 (2.5"), WS460c Gen8 Graphics Expansion (2.5"), WS460c Gen9 (2.5"), WS460c Gen9 Graphics (2.5"), WS460c Gen9 Graphics Expansion (2.5"), XL250a Gen9 Accelerator Tray (2.5")
£459.50
Save on this ideal PC Build kit!
Save £9.25
£479.06
Scroll to top
