BT.com
Wishlist
HPE HP H241 12Gb 2-ports Ext Smart Host Bus Adapter
HPE HP H241 12Gb 2-ports Ext Smart...
£170.96
Hurry, only 2 left in stock!
£170.96
Add to wishlist
Delivery
Standard 1-3 working days
Do you need a cost effective controller that provides fast access to the data on the direct attached or shared storage drives and you do not have the room in your server to add additional storage? The HP H241 Smart Host Bus Adapter comes in a low profile, PCIe3 x8 standup form factor that provides the Gen9 Servers a reliable, high performing SAS connectivity to the data in the direct attached or shared storage solutions. Featuring eight external physical links, it delivers 12 Gb/s SAS performance. The H241 Smart Host Bus Adapter provides flexibility to run as an HBA mode or simple RAID mode. When operating in simple RAID mode, it provides RAID 0, RAID 1, and RAID 5 with optional HP Secure Encryption capabilities. Unlike the HP Smart Array Controllers, the H241 does not offer any acceleration or support cache modules. The controller is also ideal for data backup to an external tape drives.
HPE H241 Smart Host Bus Adapter - storage controller - SATA 6Gb/s / SAS 12Gb/s - PCIe 3.0 x8
Storage controller - plug-in card - low profile
Bus Type
PCIe 3.0 x8
Data Transfer Rate
1.2 GBps
Supported Devices
Hard drive, solid state drive
Channel Qty
8
RAID Level
RAID 0, RAID 1, RAID 5
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Ubuntu 12.04, Microsoft Windows Server 2012, Oracle Solaris 11.1, Microsoft Windows Server 2012 R2, SuSE Linux Enterprise Server 11 SP3, Ubuntu 14.04, Microsoft Windows Server 2012 with Hyper-V, Red Hat Enterprise Linux 7, Red Hat Enterprise Linux 6 update 5
1.6 cm x 16.8 cm x 6.86 cm
1 year warranty
Apollo 4510 Gen9; Modular Smart Array 2040, 2040 10Gb; ProLiant DL160 Gen9, DL180 Gen9, DL360 Gen9, DL380 Gen9, DL560 Gen9, DL80 Gen9, ML10 Gen9, ML350 Gen9, SL210t Gen8, SL250s Gen8, SL270s Gen8, XL170r Gen9, XL230a Gen9
Host Bus
PCIe 3.0 x8
Storage Controller
Data Transfer Rate
1.2 GBps
Supported Devices
Channel Qty
8
RAID Level
2 x SATA 6Gb/s / SAS 12Gb/s - 36 pin 4x Shielded Mini MultiLane SAS (SFF-8644) (external)
Low-profile bracket
WEEE
Limited warranty - parts - 1 year
1.6 cm
16.8 cm
6.86 cm
HPE Apollo 4510 Gen9 , HPE Modular Smart Array 2040 10Gb iSCSI Dual Controller SFF Bundle, 2040 Dual Controller SFF Bundle, 2040 FC Dual Controller SFF Bundle, 2040 SAN Dual Controller SFF Bundle, 2040 SAS Dual Controller SFF Bundle , HPE ProLiant DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL360 Gen9, DL360 Gen9 Base, DL360 Gen9 CMS, DL360 Gen9 Entry, DL360 Gen9 Performance, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL560 Gen9 Entry, DL80 Gen9, ML10 Gen9, ML10 Gen9 Entry, ML10 Gen9 Performance, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance, SL210t Gen8, SL210t Gen8 1U Node, SL210t Gen8 2U Node, SL250s Gen8 2U Left Half Width Tray, SL250s Gen8 2U PCIe Gen3 Left Tray, SL250s Gen8 2U PCIe Gen3 Right Tray, SL250s Gen8 2U Right Half Width Tray, SL250s Gen8 Base 2U Left Half Width Tray, SL250s Gen8 Base 2U Left Tray Server, SL250s Gen8 Base 2U Right Half Width Tray, SL250s Gen8 Base 2U Right Tray Server, SL250s Gen8 Left Tray, SL250s Gen8 Right Tray, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray, SL270s Gen8 Base 4U Left Half Width Tray, SL270s Gen8 Base 4U Right Half Width Tray, SL270s Gen8 SE 4U Left Tray, SL270s Gen8 SE 4U Right Tray, XL170r Gen9, XL230a Gen9 Compute Tray, XL230a Gen9 Compute Tray (12G), XL230a Gen9 Compute Tray (6G), XL230a Gen9 NHP Compute Tray (12G)
Scroll to top
