BT.com
Wishlist
HPE HP E5406-44G-PoE+/4G v2 zl Switch w Prm SW
HPE HP E5406-44G-PoE+/4G v2 zl...
£5,186.18
Hurry, only 1 left in stock!
£5,186.18
Add to wishlist
Delivery
Standard 1-3 working days
The HP 5400 zl Switch Series is a HP Networking ASIC based modular switch designed for enterprise-edge, SMB, and branch office core deployments. This Layer 3 switch has 760 Gbps backplane and license free software with an advanced Layer 2 and 3 feature set including IPv6, IPv4 BGP, policy based routing, OSPF and robust QoS. Virtualization with HP AllianceOne solutions and flexible connectivity including 1 and 10 Gigabit Ethernet and PoE+, the 5400 zl Switch Series is Software-defined Network (SDN) ready with support for OpenFlow.
Aruba 5406-44G-PoE+-4G-SFP v2 zl - switch - 44 ports - Managed - rack-mountable - with HP 5400 zl Switch Premium License
Switch - 44 ports - L4 - Managed - with HP 5400 zl Switch Premium License
Enclosure Type
Rack-mountable 4U
Subtype
Gigabit Ethernet
Ports
44 x 10/100/1000 (PoE) + 4 x SFP
Power Over Ethernet (PoE)
PoE
Performance
Switching capacity: 379.2 Gbps
MAC Address Table Size
64K entries
Routing Protocol
RIP-1, RIP-2, OSPFv2, static IP routing, IGMPv3, OSPFv3, static IPv6 routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP
Flow control, routing, power over Ethernet (PoE), BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), DiffServ support, manageable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, PoE+
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 801.1p, IEEE 802.1v
AC 120/230 V ( 50/60 Hz )
44.5 cm x 45.1 cm x 17.5 cm
20.7 kg
Enclosure Type
Rack-mountable 4U
Subtype
Gigabit Ethernet
Ports
PoE
Performance
64K entries
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
1 x Freescale PowerPC 8540 : 666 MHz
RAM
256 MB - DDR SDRAM
Flash Memory
4 MB
44 x 1000Base-T - RJ-45 - PoE , 1 x RS-232C - management , 4 x SFP (mini-GBIC)
Expansion Slots
6 (total) / 4 (free) x Expansion Slot , 1 (total) / 1 (free) x CompactFlash Card
Installed Modules Qty (Max)
2 (installed) / 6 (max)
Rack Mounting Kit
Included
FCC Class A certified, CISPR 22 Class A, CISPR 24, EN 60950, EN 61000-3-2, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, VCCI Class A ITE, IEC 60950, EN 61000-3-3, EN55024, UL 60950, CSA 22.2 No. 60950
44.5 cm
45.1 cm
17.5 cm
20.7 kg
55 °C
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£5.17
£3.90
£12.74
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.12
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.70
£57.14
Scroll to top
