BT.com
Wishlist
HPE HP 900GB 12G SAS 10K 2.5in SC ENT HDD
HPE HP 900GB 12G SAS 10K 2.5in SC...
£273.91
Hurry, only 1 left in stock!
£273.91
Add to wishlist
Delivery
Standard 1-3 working days
Do your servers need high-performance SAS disk drives for both your mission-critical and storage driven applications? HPE SAS Hard Drives for enterprise and midline applications deliver high-performance solutions for hosting high transaction based applications. They are available in HPE Smart Carrier, HPE Standard Hot Plug Carrier and HPE Non-hot Plug Carrier. HPE SAS Hard Drives are available in 2.5-inch Small Form Factor (SFF) and 3.5-inch Large Form Factor (LFF) and come in a variety of capacity points to meet a wide range of requirements supporting enterprise and midline applications. The SAS interface was specifically engineered to deliver high availability where enterprise-class data storage, performance, reliability and data integrity are crucial.
HPE Enterprise - hard drive - 900 GB - SAS 12Gb/s
Hard drive - hot-swap
900 GB
2.5"
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
Spindle Speed
10000 rpm
Bundled with
HP SmartDrive carrier
ProLiant BL465c Gen8, BL660c Gen9, DL120 Gen9, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL560 Gen9, DL580 Gen9, ML110 Gen9, ML310e Gen8, ML350e Gen8, XL230a Gen9, XL250a Gen9
900 GB
2.5"
SAS 12Gb/s
Bundled with
Performance
Drive Transfer Rate
1.2 GBps (external)
Spindle Speed
10000 rpm
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
2.5"
HPE ProLiant BL465c Gen8 (2.5"), BL660c Gen9 (2.5"), DL120 Gen9 (2.5"), DL120 Gen9 Entry (2.5"), DL180 Gen9 (2.5"), DL180 Gen9 Base (2.5"), DL180 Gen9 Entry (2.5"), DL180 Gen9 Storage (2.5"), DL20 Gen9 (2.5"), DL20 Gen9 Entry (2.5"), DL20 Gen9 Performance (2.5"), DL320e Gen8 (2.5"), DL320e Gen8 Base (2.5"), DL320e Gen8 Entry (2.5"), DL320e Gen8 Performance (2.5"), DL320e Gen8 Special Server (2.5"), DL320e Gen8 v2 (2.5"), DL320e Gen8 v2 Base (2.5"), DL320e Gen8 v2 Entry (2.5"), DL320e Gen8 v2 Performance (2.5"), DL560 Gen9 (2.5"), DL560 Gen9 Base (2.5"), DL560 Gen9 Entry (2.5"), DL560 Gen9 Performance (2.5"), DL580 Gen9 (2.5"), DL580 Gen9 Database (2.5"), ML110 Gen9 (2.5"), ML110 Gen9 Base (2.5"), ML110 Gen9 Entry (2.5"), ML310e Gen8 (2.5"), ML310e Gen8 Base (2.5"), ML310e Gen8 Entry (2.5"), ML310e Gen8 Performance (2.5"), ML310e Gen8 v2 (2.5"), ML310e Gen8 v2 Base (2.5"), ML310e Gen8 v2 Enty (2.5"), ML310e Gen8 v2 Performance (2.5"), ML350e Gen8 (2.5"), ML350e Gen8 Base (2.5"), ML350e Gen8 Entry (2.5"), ML350e Gen8 Performance (2.5"), ML350e Gen8 v2 (2.5"), ML350e Gen8 v2 Base (2.5"), ML350e Gen8 v2 Entry (2.5"), XL230a Gen9 Compute Tray (2.5"), XL230a Gen9 Compute Tray (12G) (2.5"), XL230a Gen9 Compute Tray (6G) (2.5"), XL230a Gen9 NHP Compute Tray (12G), XL250a Gen9 Accelerator Tray (2.5")
£273.91
Save on this ideal PC Build kit!
Save £10.36
£293.46
Scroll to top
