BT.com
Wishlist
HPE HP 830 24P PoE Wired WLAN Switch
HPE HP 830 24P PoE Wired WLAN...
£4,225.65
£4,225.65
Add to wishlist
Delivery
Standard Due date unavailable
The HP 830 Unified Wired-WLAN Switch Series integrates both wireless controller and GbE switch functions. The switch series provides 1000 Mbps Ethernet ports, each supporting up to 30 W of PoE+ and manages IEEE 802.11a/b/g/n/ac APs to deliver unified access, consistent policy and RF optimization for your small to medium branch offices. The HP 830 24-Port PoE+ Unified Wired-WLAN Switch provides two optional 10GbE slots on the rear panel to relieve transmission bottleneck at the core of a WLAN network. The HP 830 Unified Wired-WLAN Switch Series are part of the HPN Mobility enterprise solution.
HPE 830 24-Port PoE+ Unified Wired-WLAN Switch - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 4 x shared Gigabit SFP
Power Over Ethernet (PoE)
PoE+
MAC Address Table Size
8K entries
Jumbo Frame Support
Routing Protocol
RIP-1, RIP-2, static IPv4 routing, static IPv6 routing
Remote Management Protocol
SNMP 1, RMON, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, CLI
Flow control, Layer 2 switching, DHCP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, DiffServ support, Intrusion Detection System (IDS), IPv6 support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, Endpoint Admission Defense (EAD), STP Root Guard, fan tray, MAC address lockout
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at
44 cm x 42.9 cm x 4.29 cm
7.2 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
8K entries
Jumbo Frame Support
Routing Protocol
Encryption Algorithm
AES, SSL, TLS, TKIP, WPA, WPA2, PKI, WEP
Authentication Method
RADIUS
1: 750 MHz
RAM
512 MB - DDR2 SDRAM
Flash Memory
1 GB
24 x 1000Base-T - RJ-45 - PoE+ , 1 x console - RJ-45 - management , 4 x SFP (mini-GBIC)
Expansion Slots
2 (total) / 2 (free) x Expansion Slot
Internal power supply
Rack Mounting Kit
Included
CISPR 22 Class A, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, ICES-003 Class A, RoHS, FCC CFR47 Part 15, EN300-386, UL 60950-1, IEC 60950-1, EN 60950-1, CAN/CSA C22.2 No. 60950-1, VCCI V-3 Class A ITE, VCCI V-4
44 cm
42.9 cm
4.29 cm
7.2 kg
45 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Other bundles
£4,225.65
Save on TP Link Smart Plug
Save £2.00
£4,249.62
Accessories
£4.95
£3.85
£12.21
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.72
£55.52
Scroll to top
