BT.com
Wishlist
HPE HP 82E 8Gb Dual-port PCI-e FC HBA
Delivery
Standard Due date unavailable
The introduction of the HP PCIe 8Gb Fibre Channel Host Bus Adapters brings datacenter infrastructure components to a higher level of performance and efficiency with the ability to deliver twice the I/O performance of 4 Gb FC HBAs. An 8 Gb Fibre Channel HBA purchased today is backward compatible with 4 and 2 Gb storage networks and will protect future investments. When using storage intensive applications, such as backup/restore, database transactions, virtualization, and rich media, the increased performance of the 8 Gb infrastructure enables more rapid storage and retrieval of critical information. Finally, PCIe 8Gb FC Host Bus Adapters provide a number of features that work together to reduce power consumption, thus delivering a "green" benefit within the server.
HPE 82E - host bus adapter
Host bus adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x4 / PCI Express x8
PCI Specification Revision
PCIe 2.0
Ports
8Gb Fibre Channel x 2
16.764 cm x 6.88 cm
Cabling Type
Fibre optic
4Gb Fibre Channel (SW), 2Gb Fibre Channel (SW), 8Gb Fibre Channel (SW)
Data Transfer Rate
8.5 Gbps
Emulex
Linux, Microsoft Windows Server 2003, SuSE Linux Enterprise Server 11, SuSE Linux Enterprise Server 10, Red Hat Enterprise Linux 5 for Intel x86 / AMD64 / EM64T, Microsoft Windows Server 2008, Red Hat Enterprise Linux 5.1 for Intel x86 / AMD64 / EM64T, Oracle Solaris x86 10
3 years warranty
Modular Smart Array 1040, 2040, P2000 G3; ProLiant DL160 G6, DL160 Gen8, DL165 G7, DL180 G6, DL360 G7, DL360e Gen8, DL370 G6, DL380 G7, DL380p Gen8, DL385 G7, DL385p Gen8, ML350 G6, ML370 G6, SL210t Gen8; StoreEasy 3850
Host bus adapter
PCIe 2.0
Ports
Wired
Cabling Type
Fibre optic
Data Transfer Rate
8.5 Gbps
Processor / Memory
Emulex
Expansion Slots
2 (total) / 0 (free) x SFP+
2 x 8Gb Fibre Channel (short wave) - LC multi-mode - x 2
Compatible Slots
1 x PCI Express 2.0 x4 / PCI Express x8
Low-profile bracket, full-height bracket, 2 x 8 Gb SFP
RoHS
16.764 cm
6.88 cm
Limited warranty - parts - 3 years
55 °C
5 - 95% (non-condensing)
HPE Modular Smart Array 1040 Dual Controller SFF Bundle, 2040 SAS Dual Controller LFF Storage, P2000 G3 10GbE iSCSI Dual Controller SFF Array System, P2000 G3 iSCSI Dual Controller SFF Bundle , HPE ProLiant DL160 G6, DL160 G6 Special Server, DL160 Gen8, DL160 Gen8 Entry, DL160 Gen8 Performance, DL165 G7, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Performance, DL165 G7 Special Server, DL180 G6, DL180 G6 Special Server, DL360 G7, DL360 G7 Base, DL360 G7 Central Management Server, DL360 G7 Efficiency, DL360 G7 Entry, DL360 G7 Performance, DL360 G7 Special Server, DL360e Gen8, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL370 G6, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL370 G6 Special Server, DL380 G7, DL380 G7 Base, DL380 G7 Efficiency, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Special, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL385p Gen8, DL385p Gen8 Dedicated Workload, DL385p Gen8 Entry, DL385p Gen8 Maximized Consolidation, DL385p Gen8 Storage, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML350 G6 Special Server, ML370 G6, ML370 G6 Base, ML370 G6 Entry, ML370 G6 Special Server, SL210t Gen8 1U Node , HPE StoreEasy 3850 Gateway Single Node
Scroll to top
