BT.com
Wishlist
HPE HP 750W Common Slot Platinum Plus Hot Plug Power S
HPE HP 750W Common Slot Platinum...
£220.04
£220.04
Add to wishlist
Delivery
Standard Due date unavailable
Looking to reduce energy cost and space with increased performance? HP Common Slot Power Supplies share a common electrical and physical design that allows for hot-swap, tool-less installation into HP server and storage solutions. These power supplies are available in multiple, high-efficiency input and output options, allowing you to "right-size" a power supply for specific server/storage configurations and environments. This flexibility helps to reduce power waste, lower overall energy costs, and avoid "trapped" power capacity in the data center. The power supplies provide the IT industry's highest level of power efficiency (up to 96%), helping users to reduce power requirements per server and reducing overall data center power requirements. The Platinum Plus and Titanium power supplies also enable HP Power Discovery Services which focus on increasing compute density while reducing data center outages.
HPE Common Slot Platinum Plus Power Supply Kit - power supply - hot-plug - 750 Watt
Power supply - hot-plug - plug-in module
80 PLUS Certification
80 PLUS Platinum
Input Voltage
AC 100-240 V
Power Capacity
750 Watt
ProLiant DL160 Gen8, DL360e Gen8, DL360p Gen8, DL380p Gen8, DL385p Gen8, ML350e Gen8, ML350p Gen8, SL210t Gen8, SL230s Gen8, SL250s Gen8, SL4540 Gen8, SL4545 G7
Input Voltage
AC 100-240 V
Frequency Required
50/60 Hz
Power Capacity
750 Watt
80 PLUS Platinum
HPE ProLiant DL160 Gen8 (750 Watt), DL160 Gen8 Base (750 Watt), DL160 Gen8 Entry (750 Watt), DL160 Gen8 Performance (750 Watt), DL360e Gen8 (750 Watt), DL360e Gen8 Entry (750 Watt), DL360e Gen8 Performance (750 Watt), DL360e Gen8 Special Server (750 Watt), DL360p Gen8 (750 Watt), DL360p Gen8 Base (750 Watt), DL360p Gen8 CMS (750 Watt), DL360p Gen8 Entry (750 Watt), DL360p Gen8 High Performance (750 Watt), DL380p Gen8 (750 Watt), DL380p Gen8 Base (750 Watt), DL380p Gen8 Entry (750 Watt), DL380p Gen8 High Performance (750 Watt), DL380p Gen8 Special (750 Watt), DL385p Gen8 (750 Watt), DL385p Gen8 Dedicated Workload (750 Watt), DL385p Gen8 Entry (750 Watt), DL385p Gen8 Maximized Consolidation (750 Watt), DL385p Gen8 Storage (750 Watt), ML350e Gen8 (750 Watt), ML350e Gen8 Base (750 Watt), ML350e Gen8 Entry (750 Watt), ML350e Gen8 Performance (750 Watt), ML350e Gen8 v2 (750 Watt), ML350e Gen8 v2 Base (750 Watt), ML350p Gen8 (750 Watt), ML350p Gen8 Base (750 Watt), ML350p Gen8 Entry (750 Watt), ML350p Gen8 Performance (750 Watt), ML350p Gen8 Special Server (750 Watt), SL210t Gen8 1U Node (750 Watt), SL230s Gen8 1U Left Half Width Tray (750 Watt), SL230s Gen8 1U Right Half Width Tray (750 Watt), SL230s Gen8 Base 1U Left Tray Server (750 Watt), SL230s Gen8 Base 1U Right Tray Server (750 Watt), SL250s Gen8 2U Left Half Width Tray (750 Watt), SL250s Gen8 2U PCIe Gen3 Left Tray (750 Watt), SL250s Gen8 2U PCIe Gen3 Right Tray (750 Watt), SL250s Gen8 2U Right Half Width Tray (750 Watt), SL250s Gen8 Base 2U Left Half Width Tray (750 Watt), SL250s Gen8 Base 2U Left Tray Server (750 Watt), SL250s Gen8 Base 2U Right Half Width Tray (750 Watt), SL250s Gen8 Base 2U Right Tray Server (750 Watt), SL4540 Gen8 (750 Watt), SL4540 Gen8 Tray 2x Node Server (750 Watt), SL4545 G7
Scroll to top
