BT.com
Wishlist
HPE HP 7.3K VA 230V 30OUT Basic Power Distribution Unit
HPE HP 7.3K VA 230V 30OUT Basic...
£200.79
£200.79
Add to wishlist
Delivery
Standard Due date unavailable
With simple 0U and 1U installation options, HPE Basic Power Distribution Units are available in multiple form factors allowing you to configure access to power in your rack where you need it the most. HPE Basic PDUs provide a low-profile single-piece design allowing easy access to rear devices for maintenance. Vertical PDUs can be installed on either side of the rack with outlets facing the back of the rack for easy access and improved clearance. For higher power density configurations, they can be installed side by side on both sides of the rack with the outlets facing towards the center. Horizontal/Modular PDUs offer a modular architecture designed for data center customers who want to maximize power distribution and space efficiencies. The Control Unit or core can be mounted in any 1U space or in 0U space on the side of HPE Racks between the RETMA rails. Extension Bars mount directly to the frame so you can configure access to power where you need it.
HPE Basic Power Distribution Unit - power distribution unit - 7360 VA
Power distribution unit
Japan, North America
Output Voltage
230 V
Power Capacity
7360 VA
Input Connectors
Power IEC 60320 C13, power IEC 60320 C19
Output connectors
24 x power IEC 60320 C13 , 6 x power IEC 60320 C19
48 cm x 9.5 cm x 140 cm
Apollo 4510 Gen9; ProLiant c3000, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML350e Gen8 v2, ML350e Gen8 v2 Base, SL210t Gen8 1U Node, SL250s Gen8 Left Tray, SL250s Gen8 Right Tray, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray
Input Voltage Range
AC 200 - 240 V
Input Connectors
Output Voltage
230 V
Max Electric Current
32 A
Power Capacity
7360 VA
1 x power cable - integrated - 2.4 m
UL, cUL
48 cm
9.5 cm
140 cm
HPE Apollo 4510 Gen9 , HPE ProLiant c3000, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML350e Gen8 v2, ML350e Gen8 v2 Base, SL210t Gen8 1U Node, SL250s Gen8 Left Tray, SL250s Gen8 Right Tray, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray
Scroll to top
