BT.com
Wishlist
HPE HP 500GB 7.2K RPM 2.5 SAS Hard Disk Drive
HPE HP 500GB 7.2K RPM 2.5 SAS Hard...
£188.44
Hurry, only 1 left in stock!
£188.44
Add to wishlist
Delivery
Standard 1-3 working days
Serial Attached SCSI (SAS) provides a superior storage solution. With some storage requirements escalating and others becoming more complex, factors such as flexibility, performance, increased reliability, greater density, security, scalability and accessibility are more critical than ever.
SAS Midline hard drives are ideal for servers or external storage for high-capacity, non mission-critical environments with less than 40% workloads requiring economical reliability (about twice that of entry drives) and redundant data paths to the drive, e.g. disk backup, archival, reference, and other highly available applications.
HPE Dual Port Midline - hard drive - 500 GB - SAS 6Gb/s
Hard drive - internal
500 GB
2.5" SFF
SAS 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
Bundled with
HP SmartDrive carrier
ProLiant BL420c Gen8, BL460c Gen8, BL465c Gen8, BL660c Gen8, BL660c Gen9, DL160 Gen8, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360 Gen9, DL360e Gen8, DL360p Gen8, DL380 Gen9, DL380e Gen8, DL380p Gen8, DL385p Gen8, DL560 Gen8, DL560 Gen9, DL580 Gen9, ML110 Gen9, ML30 Gen9, ML310e Gen8, ML350 Gen9, ML350e Gen8, ML350p Gen8, SL230s Gen8, SL250s Gen8, SL270s Gen8, WS460c Gen9, XL170r Gen9, XL190r Gen9, XL220a Gen8, XL230a Gen9, XL250a Gen9
500 GB
2.5" SFF
SAS 6Gb/s
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SAS 6Gb/s
Compatible Bay
2.5" SFF
HPE ProLiant BL460c Gen8 (2.5"), BL660c Gen8 (2.5"), BL660c Gen9 (2.5"), DL180 Gen9 (2.5"), DL180 Gen9 Base (2.5"), DL180 Gen9 Entry (2.5"), DL180 Gen9 Storage (2.5"), DL20 Gen9 (2.5"), DL20 Gen9 Entry (2.5"), DL20 Gen9 Performance (2.5"), DL320e Gen8 (2.5"), DL320e Gen8 Base (2.5"), DL320e Gen8 Entry (2.5"), DL320e Gen8 Performance (2.5"), DL360 Gen9 CMS (2.5"), DL360e Gen8 Special Server (2.5"), DL360p Gen8 (2.5"), DL360p Gen8 CMS (2.5"), DL360p Gen8 Special Server (2.5"), DL380 Gen9 (2.5"), DL380 Gen9 Base (2.5"), DL380 Gen9 Entry (2.5"), DL380 Gen9 Performance (2.5"), DL385p Gen8 Entry (2.5"), DL560 Gen8 (2.5"), DL560 Gen8 Base (2.5"), DL560 Gen8 Entry (2.5"), DL560 Gen8 Performance (2.5"), DL560 Gen9 (2.5"), DL560 Gen9 Base (2.5"), DL560 Gen9 Entry (2.5"), DL560 Gen9 Performance (2.5"), DL580 Gen9 (2.5"), DL580 Gen9 Database (2.5"), ML110 Gen9 (2.5"), ML110 Gen9 Base (2.5"), ML110 Gen9 Entry (2.5"), ML30 Gen9 (2.5"), ML30 Gen9 Base (2.5"), ML30 Gen9 Performance (2.5"), ML310e Gen8 (2.5"), ML310e Gen8 Base (2.5"), ML310e Gen8 Entry (2.5"), ML310e Gen8 Performance (2.5"), ML310e Gen8 v2 Base (2.5"), ML350 Gen9 (2.5"), ML350 Gen9 Base (2.5"), ML350 Gen9 Entry (2.5"), ML350 Gen9 Performance (2.5"), ML350e Gen8 v2 (2.5"), ML350p Gen8 (2.5"), SL250s Gen8 2U PCIe Gen3 Left Tray (2.5"), SL250s Gen8 2U PCIe Gen3 Right Tray (2.5"), SL250s Gen8 Left Tray (2.5"), SL250s Gen8 Right Tray (2.5"), SL270s Gen8 1U Left Half Width Tray (2.5"), SL270s Gen8 1U Right Half Width Tray (2.5"), SL270s Gen8 Base 4U Left Half Width Tray (2.5"), SL270s Gen8 Base 4U Right Half Width Tray (2.5"), SL270s Gen8 SE 4U Left Tray (2.5"), SL270s Gen8 SE 4U Right Tray (2.5"), WS460c Gen9 Graphics (2.5"), WS460c Gen9 Graphics Expansion (2.5"), XL170r Gen9 (2.5"), XL190r Gen9 (2.5"), XL220a Gen8 v2 (2.5"), XL230a Gen9 Compute Tray (2.5"), XL230a Gen9 Compute Tray (12G) (2.5"), XL230a Gen9 Compute Tray (6G) (2.5"), XL250a Gen9 Accelerator Tray (2.5")
£188.44
Save on this ideal PC Build kit!
Save £9.16
£208.00
Scroll to top
