BT.com
Wishlist
HPE HP 500GB 6G SATA 7.2K RPM 3.5" SC Midline
HPE HP 500GB 6G SATA 7.2K RPM 3.5"...
£112.96
16 in stock
£112.96
Add to wishlist
Delivery
Standard 1-3 working days
Do you have non-mission critical applications that require economical high capacity and reliability hard disk drives? HPE SATA Hard Drives are built for reliability and larger capacity needs for today's non-mission critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HPE SATA Hard Drives are available in both Large Form Factor (LFF) (3.5-inch) and Small Form Factor (SFF) (2.5-inch) and ship with a standard one-year warranty. All HPE hard drives pass a rigorous qualification process, which certify that every HPE drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
HPE Midline - hard drive - 500 GB - SATA 6Gb/s
Hard drive - hot-swap
500 GB
3.5" LFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
1 year warranty
Bundled with
HP SmartDrive carrier
ProLiant DL320e Gen8, DL360e Gen8, DL380e Gen8, DL385p Gen8, ML310e Gen8, ML350e Gen8
500 GB
3.5" LFF
SATA 6Gb/s
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" LFF
1 year warranty
Limited warranty - 1 year
Scroll to top
