BT.com
Wishlist
HPE HP 460W CS Plat Power Supply Kit
HPE HP 460W CS Plat Power Supply...
£204.49
£204.49
Add to wishlist
Delivery
Standard Due date unavailable
Looking to reduce energy cost and space with increased performance? HP Common Slot Power Supplies share a common electrical and physical design that allows for hot-swap, tool-less installation into HP server and storage solutions. These power supplies are available in multiple, high-efficiency input and output options, allowing you to "right-size" a power supply for specific server/storage configurations and environments. This flexibility helps to reduce power waste, lower overall energy costs, and avoid "trapped" power capacity in the data center. The power supplies provide the IT industry's highest level of power efficiency (up to 96%), helping users to reduce power requirements per server and reducing overall data center power requirements. The Platinum Plus and Titanium power supplies also enable HP Power Discovery Services which focus on increasing compute density while reducing data center outages.
HPE - power supply - hot-plug / redundant - 460 Watt
Power supply - hot-plug / redundant - plug-in module
Specification Compliance
Common Slot
80 PLUS Certification
80 PLUS Platinum
1.13 kg
Input Voltage
AC 100-240 V
Power Capacity
460 Watt
3.81 cm x 19.05 cm x 8.63 cm
ProLiant DL160 Gen8, DL320e Gen8, DL360e Gen8, DL360p Gen8, DL380p Gen8, DL385p Gen8, ML350e Gen8, ML350p Gen8
Common Slot
Input Voltage
AC 100-240 V
Input Voltage Range
AC 90 - 132 / 180 - 264 V
Frequency Required
50/60 Hz
Power Capacity
460 Watt
Efficiency
94%
80 PLUS Platinum
FCC Class B certified
5 °C
50 °C
5 - 95% (non-condensing)
3.81 cm
19.05 cm
8.63 cm
1.13 kg
Shipping Width
39.37 cm
Shipping Depth
13.97 cm
Shipping Height
18.44 cm
Shipping Weight
1.59 kg
HPE ProLiant DL160 Gen8 (460 Watt), DL160 Gen8 Base (460 Watt), DL160 Gen8 Entry (460 Watt), DL160 Gen8 Performance (460 Watt), DL320e Gen8 Base (460 Watt), DL320e Gen8 Performance (460 Watt), DL360e Gen8 (460 Watt), DL360e Gen8 Entry (460 Watt), DL360e Gen8 Performance (460 Watt), DL360e Gen8 Special Server (460 Watt), DL360p Gen8 (460 Watt), DL360p Gen8 Base (460 Watt), DL360p Gen8 Entry (460 Watt), DL360p Gen8 High Performance (460 Watt), DL380p Gen8 (460 Watt), DL380p Gen8 Base (460 Watt), DL380p Gen8 Entry (460 Watt), DL380p Gen8 High Performance (460 Watt), DL380p Gen8 Performance (460 Watt), DL380p Gen8 Special (460 Watt), DL385p Gen8 (460 Watt), DL385p Gen8 Dedicated Workload (460 Watt), DL385p Gen8 Entry (460 Watt), DL385p Gen8 Maximized Consolidation (460 Watt), DL385p Gen8 Storage (460 Watt), ML350e Gen8 (460 Watt), ML350e Gen8 Base (460 Watt), ML350e Gen8 Entry (460 Watt), ML350e Gen8 Performance (460 Watt), ML350e Gen8 v2 (460 Watt), ML350e Gen8 v2 Base (460 Watt), ML350p Gen8 (460 Watt), ML350p Gen8 Base (460 Watt), ML350p Gen8 Entry (460 Watt), ML350p Gen8 Special Server (460 Watt)
Scroll to top
