BT.com
Wishlist
HPE HP 3800-24SFP-2SFP+ Switch
£6,243.46
£6,243.46
Add to wishlist
Delivery
Standard 1-3 working days
The HPE 3800 Switch Series provides performance, resiliency, flexibility, and ease of use for enterprise edge, SMB and branch office deployments. Based on a powerful ProVision ASIC, the switch has low latency, increased packet buffering, and adaptive power consumption. Mesh-stacking technology delivers modular chassis-like resiliency in stackable 1U form factor. The HPE 3800 Switch Series has a robust Layer 3 feature set with IPv6, IPv4 BGP, policy based routing, and OSPF. It is SDN ready with OpenFlow support.
Aruba 3800-24SFP-2SFP+ - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L4 - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x Gigabit SFP + 2 x 10 Gigabit Ethernet / 1 Gigabit Ethernet SFP+
Performance
Throughput: 65.4 Mpps , Switching capacity: 88 Gbps
Routing table entries: 10000
MAC Address Table Size
65500 entries
Jumbo Frame Support
Routing Protocol
OSPF, RIP-1, RIP-2, IGMP, VRRP, OSPFv2, PIM-SM, static IP routing, PIM-DM, OSPFv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, CLI
Flow control, Layer 2 switching, DHCP support, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DiffServ support, IPv6 support, sFlow, Rapid Spanning Tree Protocol (RSTP) support, Virtual Route Redundancy Protocol (VRRP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), MLD snooping, STP Root Guard, Uni-Directional Link Detection (UDLD), fan tray, MAC address lockout
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.1v, IEEE 802.3an
Power Redundancy
Optional
44.3 cm x 46.7 cm x 4.3 cm
7.3 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
65500 entries
Jumbo Frame Support
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
2
RAM
2 GB - SDRAM
Flash Memory
4 GB
24 x 100Base-TX/1000Base-T - SFP (mini-GBIC) , 2 x 10Gb Ethernet - SFP+ , 1 x console - RJ-45 - management , 1 x RJ-45 - management
Expansion Slots
1 (total) / 1 (free) x Stacking Module
Installed Qty
1 (installed) / 2 (max)
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Rack Mounting Kit
Included
FCC Class A certified, CISPR 24, EN 61000-3-2, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, VCCI Class A ITE, EN 61000-3-3, UL 60950, CSA 22.2 No. 60950, RoHS, IEC 60950-1, EN 60950-1, EN 60825
44.3 cm
46.7 cm
4.3 cm
7.3 kg
45 °C
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
15 - 90% (non-condensing)
Accessories
£5.16
£3.90
£12.61
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.01
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£57.07
Scroll to top
