BT.com
Wishlist
HPE HP 3600-24-POE+ V2 SI Switch
£1,170.75
£1,170.75
Add to wishlist
Delivery
Standard Due date unavailable
The HP 3600 SI Switch Series delivers resiliency, security, and reliability at the enterprise edge. This Basic Layer 3 Fast Ethernet switch series supports IRF stacking, Static & RIP Routing, ACLs, IPv6, and PoE+. The HP 3600 SI Switch Series can be managed with the optional HP Intelligent Management Center (IMC) Software Platform for a single view of your entire network and includes a Limited Lifetime Warranty 2.0 with 3 years 24x7 phone support.
HPE 3600-24-PoE+ v2 SI Switch - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
24 x 10/100 (PoE+) + 4 x Gigabit SFP + 2 x shared 10/100/1000
Power Over Ethernet (PoE)
PoE+
PoE Budget
720 W
Performance
Throughput: 9.5 Mpps , Routing/switching capacity: 12.8 Gbps
IPv4 routing table entries: 2048
Jumbo Frame Support
9216 bytes
Routing Protocol
RIP-1, RIP-2, IGMP, VRRP, static IPv4 routing, static IPv6 routing, RIPng, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTPS, CLI
Flow control, routing, Layer 2 switching, DHCP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, IPv6 support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Route Redundancy Protocol (VRRP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Committed Access Rate (CAR), Jumbo Frames support, MLD snooping, Device Link Detection Protocol (DLDP) support, Rapid Ring Protection Protocol (RRPP) support, Bidirectional Forwarding Detection (BFD), Endpoint Admission Defense (EAD), STP Root Guard, dynamic ARP protection, Generic Attribute Registration Protocol (GARP), Intelligent Resilient Framework Technology (IRF)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.1v, IEEE 802.1ab (LLDP), IEEE 802.3at
44 cm x 42 cm x 4.36 cm
10 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
PoE+
PoE Budget
720 W
Performance
Jumbo Frame Support
9216 bytes
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, Secure Shell v.2 (SSH2), HWTACACS
RAM
256 MB SDRAM
Flash Memory
128 MB
24 x LAN - RJ-45 - PoE+ , 4 x Gigabit LAN - SFP , 2 x 1000Base-T - RJ-45 , 1 x serial (console) - RJ-45
Internal power supply
795 Watt
Rack Mounting Kit
Included
FCC Class A certified, CISPR 22 Class A, EN 61000-3-2, EN 61000-3-3, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EMC, ICES-003 Class A, EN 61000-4-5, EN 61000-4-11, RoHS, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, WEEE, CSA C22.2 No. 60950-1, EN 60825-1, EN 60825-2
44 cm
42 cm
4.36 cm
10 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day
50 °C
5 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Accessories
£4.95
£3.74
£11.19
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.02
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.61
£50.74
Scroll to top
