BT.com
Wishlist
HPE HP 3100-24-PoE v2 EI 24 Port Managed Rack Mountable Switch
HPE HP 3100-24-PoE v2 EI 24 Port...
£1,417.89
£1,417.89
Add to wishlist
Delivery
Standard Due date unavailable
The HPE 3100 EI Switch Series enhances security by providing reliable fully, managed Fast Ethernet Layer 2 switches ideal for the access layer of medium and large enterprises. Features include enterprise class quality of service (QoS) and security features including rate limiting, QinQ, ACLs, a 24-port PoE model, and improved reliability with backup redundancy. The 3100 EI Switch Series can be managed with the optional HPE Intelligent Management Center (IMC) Software Platform for a single view of your entire network.
HPE 3100-24-PoE v2 EI Switch - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
24 x 10/100 (PoE) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
Performance
Throughput: up to 6.5 Mpps , Routing/switching capacity: 8.8 Gbps
Remote Management Protocol
SNMP 1, RMON, Telnet, SNMP 3, SNMP 2c, HTTPS, CLI
Flow control, DHCP support, power over Ethernet (PoE), ARP support, VLAN support, IGMP snooping, Weighted Round Robin (WRR) queuing, IPv6 support, Virtual Cable Test (VCT) technology, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, MLD snooping, Device Link Detection Protocol (DLDP) support, STP Root Guard, LLDP support, Port Security, IP-MAC binding, dynamic ARP protection, DHCP protection, Multicast VLAN Registration (MVR), Dynamic VLAN Support (GVRP), Strict Priority Queuing (SPQ), port isolation
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1x, IEEE 802.1ab (LLDP)
44 cm x 42 cm x 4.36 cm
6.5 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
PoE
Performance
Max Units In A Stack
16
Encryption Algorithm
SSL
Authentication Method
RADIUS, Secure Shell v.2 (SSH2)
RAM
128 MB SDRAM
Flash Memory
16 MB
24 x 100Base-TX - RJ-45 - PoE , 1 x console - RJ-45 - management , 2 x 1000Base-TX - RJ-45 , 2 x SFP (mini-GBIC)
Internal power supply
Rack Mounting Kit
Included
CISPR 22 Class A, GOST, EN 61000-3-2, NOM, VCCI Class A ITE, EN 61000-3-3, EN55022 Class A, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, EMC, ICES-003 Class A, EN 61000-4-5, EN 61000-4-11, RoHS, FCC CFR47 Part 15, EN300-386, UL 60950-1, IEC 60950-1, EN 60950-1, EN 60825-1, FCC Part 15 B Class A, CAN/CSA C22.2 No. 60950-1, ANSI C63.4, EN 60825-2
44 cm
42 cm
4.36 cm
6.5 kg
Limited warranty - lifetime
45 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
Scroll to top
