BT.com
Wishlist
HPE HP 2TB 6G SATA 7200rpm LFF 3.5" SC Midline 1yr Warranty HDD
HPE HP 2TB 6G SATA 7200rpm LFF 3.5"...
£202.54
Hurry, only 2 left in stock!
£202.54
Add to wishlist
Delivery
Standard 1-3 working days
Do you have non-mission critical applications that require economical high capacity and reliability hard disk drives? HPE SATA Hard Drives are built for reliability and larger capacity needs for today's non-mission critical server applications and storage environments. These high-capacity drives provide the lowest $/GB, and the best price advantage for non-mission critical applications with low workloads of 40% or less. HPE SATA Hard Drives are available in both Large Form Factor (LFF) (3.5-inch) and Small Form Factor (SFF) (2.5-inch) and ship with a standard one-year warranty. All HPE hard drives pass a rigorous qualification process, which certify that every HPE drive is proven to perform in your HPE ProLiant Server environments. Before final certification, all HPE SATA Hard Drives are optimized for compatibility and functionality, including support of SMART and HPE Systems Insight Manager.
HPE Midline - hard drive - 2 TB - SATA 6Gb/s
Hard drive - hot-swap
2 TB
3.5" LFF
SATA 6Gb/s
Data Transfer Rate
600 MBps
Spindle Speed
7200 rpm
1 year warranty
Bundled with
HP SmartDrive carrier
ProLiant DL160 Gen8, DL180 Gen9, DL20 Gen9, DL320e Gen8, DL360 Gen9, DL360e Gen8, DL360p Gen8, DL380 Gen9, DL380e Gen8, DL380p Gen8, DL385p Gen8, DL80 Gen9, ML110 Gen9, ML30 Gen9, ML310e Gen8, ML350 Gen9, ML350e Gen8, ML350p Gen8, SL210t Gen8, SL230s Gen8, SL250s Gen8, SL270s Gen8, SL4540 Gen8, SL4545 G7; StoreEasy 1650
2 TB
3.5" LFF
SATA 6Gb/s
Bundled with
Performance
Drive Transfer Rate
600 MBps (external)
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" LFF
Limited warranty - 1 year
HPE ProLiant DL180 Gen9 (3.5"), DL180 Gen9 Base (3.5"), DL180 Gen9 Entry (3.5"), DL180 Gen9 Storage (3.5"), DL20 Gen9 (3.5"), DL20 Gen9 Entry (3.5"), DL20 Gen9 Performance (3.5"), DL320e Gen8 (3.5"), DL320e Gen8 Base (3.5"), DL320e Gen8 Entry (3.5"), DL320e Gen8 Performance (3.5"), DL320e Gen8 v2 (3.5"), DL320e Gen8 v2 Base (3.5"), DL320e Gen8 v2 Performance (3.5"), DL360 Gen9 CMS (3.5"), DL360e Gen8 Special Server (3.5"), DL360p Gen8 (3.5"), DL360p Gen8 CMS (3.5"), DL360p Gen8 Performance (3.5"), DL380 Gen9 (3.5"), DL380 Gen9 Base (3.5"), DL380 Gen9 Entry (3.5"), DL380 Gen9 Performance (3.5"), DL380e Gen8 (3.5"), DL380e Gen8 Entry (3.5"), DL380p Gen8 Performance (3.5"), DL385p Gen8 (3.5"), DL385p Gen8 Dedicated Workload (3.5"), DL385p Gen8 Entry (3.5"), DL385p Gen8 Storage (3.5"), DL385p Gen8 Storage Centric (3.5"), DL80 Gen9 (3.5"), DL80 Gen9 Entry (3.5"), ML110 Gen9 (3.5"), ML110 Gen9 Base (3.5"), ML110 Gen9 Entry (3.5"), ML30 Gen9 (3.5"), ML30 Gen9 Base (3.5"), ML30 Gen9 Performance (3.5"), ML310e Gen8 (3.5"), ML310e Gen8 Base (3.5"), ML310e Gen8 Entry (3.5"), ML310e Gen8 Performance (3.5"), ML310e Gen8 v2 (3.5"), ML310e Gen8 v2 Base (3.5"), ML310e Gen8 v2 Enty (3.5"), ML310e Gen8 v2 Performance (3.5"), ML350 Gen9 (3.5"), ML350 Gen9 Base (3.5"), ML350 Gen9 Entry (3.5"), ML350 Gen9 Performance (3.5"), ML350e Gen8 (3.5"), ML350e Gen8 v2 (3.5"), ML350e Gen8 v2 Base (3.5"), ML350p Gen8 (3.5"), ML350p Gen8 Special Server (3.5"), SL210t Gen8 (3.5"), SL210t Gen8 1U Node (3.5"), SL250s Gen8 2U PCIe Gen3 Left Tray (3.5"), SL250s Gen8 2U PCIe Gen3 Right Tray (3.5"), SL270s Gen8 1U Left Half Width Tray (3.5"), SL270s Gen8 1U Right Half Width Tray (3.5"), SL270s Gen8 Base 4U Left Half Width Tray (3.5"), SL270s Gen8 Base 4U Right Half Width Tray (3.5"), SL270s Gen8 SE 4U Left Tray (3.5"), SL270s Gen8 SE 4U Right Tray (3.5"), SL4540 Gen8 (3.5"), SL4540 Gen8 Tray 2x Node Server (3.5"), SL4545 G7 (3.5") , HPE StoreEasy 1650
HPE HP 2TB 6G SATA 7200rpm LFF 3.5" SC Midline 1yr...
£202.54
Save on this ideal PC Build kit!
Save £9.16
£222.10
Cables - Cables
£202.54
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.61
£206.15
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been opened but is in excellent condition
Ref: 8GKF 034894
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£135.28
Ref: 8GKF 034895
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£135.28
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
