BT.com
Wishlist
HPE HP 2620-24 24-Port PPoE+ Switch
HPE HP 2620-24 24-Port PPoE+...
£387.26
£387.26
Add to wishlist
Delivery
Standard Due date unavailable
The HPE 2620 Switch Series provides cost-effectiveness, flexibility, and ease of use for enterprise edge, SMB, and branch office access layer deployments. This Fast Ethernet switch has a robust Basic Layer 3 feature set with static and RIP routing, PoE+, ACLs, sFlow, IPv6, and requires no software licensing. The HPE 2620 Switch Series is easy to use and deploy, and delivers consistent wired/wireless user experience with unified management tools such as ClearPass Policy Manager and Airwave Network Management.
Aruba 2620-24-PPoE+ - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L4 - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
12 x 10/100 (PoE) + 12 x 10/100 + 2 x SFP
Power Over Ethernet (PoE)
PoE
Performance
Routing/switching capacity: 12.8 Gbps , Throughput: up to 9.5 Mpps
MAC Address Table Size
16000 entries
Jumbo Frame Support
9220 bytes
Routing Protocol
RIP-1, RIP-2, IGMPv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 2, RMON, Telnet, SNMP 3, SNMP 2c, HTTPS, TFTP, SMON
Flow control, auto-sensing per device, DHCP support, power over Ethernet (PoE), ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, IPv6 support, sFlow, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, PoE+, STP Root Guard, LLDP support, MAC address lockout, dynamic ARP protection, DHCP protection, per-port broadcast throttling
IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP), IEEE 802.3at
44.3 cm x 25.4 cm x 4.4 cm
3.2 kg
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
PoE
Performance
16000 entries
Jumbo Frame Support
9220 bytes
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2)
1 x Freescale MPC8313: 400 MHz
RAM
512 MB
Flash Memory
4 MB
12 x 10Base-T/100Base-TX - RJ-45 , 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 12 x 10Base-T/100Base-TX - RJ-45 - PoE , 1 x console - RJ-45 - management
External power adapter
Rack Mounting Kit
Included
FCC Class A certified, CISPR 22 Class A, CISPR 24, EN 60950, EN 61000-3-2, EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, VCCI Class A ITE, IEC 60950, EN 61000-3-3, EN55024, UL 60950, CSA 22.2 No. 60950, EN 60825
44.3 cm
25.4 cm
4.4 cm
3.2 kg
55 °C
15 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
15 - 90% (non-condensing)
Accessories
£4.95
£3.79
£11.67
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.34
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.64
£52.82
Scroll to top
