BT.com
Wishlist
HPE HP 1950-48G-2SFP+-2XGT Switch
£1,053.21
£1,053.21
Add to wishlist
Delivery
Standard Due date unavailable
The HPE 1950 Switch Series is a family of smart web-managed Gigabit switches with 10GbE uplinks for small business customers needing advanced high-performance connections. The series has 2 standard and 2 PoE+ models, 24- and 48-GbE ports, each with 2 10GBASE-T and 2 10G SFP+ high-bandwidth ports. True stacking of as many as 4 devices allows them to be logically administered as a single entity. The switches support Layer 3 static routing on IPv4 and IPv6. Other advanced features include ACLs, 802.1X, STP, RSTP, and MSTP. Limited lifetime warranty covers unit, fans and power supplies.
HPE 1950-48G-2SFP+-2XGT - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 2 x Gigabit SFP / 10 Gigabit SFP+ + 2 x 10Gb Ethernet
Performance
Throughput (64-byte packet size): up to 130.9 Mpps , Routing/switching capacity: 176 Gbps
Static routes: 32 , Virtual interfaces (VLANs): 8 , IPv4 routing table entries: 32 , IPv6 routing table entries: 32
MAC Address Table Size
16384 entries
Jumbo Frame Support
10KB
Routing Protocol
IGMP, VRRP, static IPv4 routing, static IPv6 routing, ECMP
Remote Management Protocol
SNMP 1, RMON 2, RMON, SNMP 3, SNMP 2c, HTTP, HTTPS, CLI
Auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, Spanning Tree Protocol (STP) support, Access Control List (ACL) support, Quality of Service (QoS), STP Root Guard, Link Aggregation Control Protocol (LACP), DHCP client, packet storm protection, Class of Service (CoS)
IEEE 802.3, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at
44 cm x 27 cm x 4.4 cm
5 kg
Bundled Services
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16384 entries
Jumbo Frame Support
10KB
Routing Protocol
RAM
1 GB (max)
Flash Memory
128 MB
48 x 1000Base-T - RJ-45 , 2 x Gigabit / 10Gbit LAN - SFP+ , 2 x 10GBase-T - RJ-45 , 1 x console - RJ-45 - management
Internal power supply
MTBF
51 years
CISPR 22 Class A, EN 61000-3-3, EN55024, EN55022 Class A, UL 60950, ICES-003 Class A, RoHS, IEC 60950-1, EN 60950-1, WEEE, FCC Part 15 A, VCCI Class A, EN 61000-3-2:2000, GB 4943.1
44 cm
27 cm
4.4 cm
5 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day
45 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
Accessories
£5.16
£3.90
£12.61
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£9.01
C2G TruLink Media Gateway RJ45 Cap
Quicklinx: 8Q37 | In Stock
£0.69
£57.07
Scroll to top
