BT.com
Wishlist
HPE HP 1920-48G-PoE+ Switch 48 ports Managed Desktop/Rack-Mountable
HPE HP 1920-48G-PoE+ Switch 48...
£957.52
15 in stock
£957.52
Add to wishlist
Delivery
Standard 1-3 working days
The HPE 1920 Switch Series, part of the HPE OfficeConnect portfolio, is designed for smaller organizations dealing with bandwidth-demanding applications. The switches are ideal for environments that require advanced features for granular control and where smart-managed flexibility is a must for easy network configuration and management. The switches deliver advanced smart-managed fixed configuration Gigabit switches that build on the marketing-leading price/performance of the HPE 1910 Switch Series. They feature a new 48-port PoE+ model, IPv6 support and advanced silicon technology.
HPE 1920-48G-PoE+ - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L3 - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 4 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
370 W
Performance
Throughput: 77.4 Mpps , Routing/switching capacity: 104 Gbps
IPv4 routing table entries: 32 , IPv6 routing table entries: 32
MAC Address Table Size
16384 entries
Jumbo Frame Support
10KB
Routing Protocol
Static IPv4 routing, static IPv6 routing
Remote Management Protocol
SNMP 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, CLI
Flow control, Layer 2 switching, auto-negotiation, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping, Cable Diagnostics Function, STP Root Guard, DHCP relay, Port Security, DHCP client, dual firmware images, Strict Priority Queuing (SPQ), port isolation, static routing, Class of Service (CoS), Single IP Management (SIM)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
44 cm x 44 cm x 4.4 cm
4.3 kg
Bundled Services
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
370 W
Performance
16384 entries
Jumbo Frame Support
10KB
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS
1 x MIPS: 650 MHz
RAM
128 MB SDRAM
Flash Memory
32 MB
48 x 1000Base-T - RJ-45 - PoE+ , 4 x 1000Base-X - SFP , 1 x console - RJ-45 - management
492 Watt
Rack Mounting Kit
Included
MTBF
44,44 years
CISPR 22 Class A, EN 61000-3-3, EN55024, EN55022 Class A, UL 60950, ICES-003 Class A, RoHS, IEC 60950-1, EN 60950-1, WEEE, FCC Part 15 A, CAN/CSA C22.2 No. 60950-1-03, VCCI Class A, EN 61000-3-2:2000
44 cm
44 cm
4.4 cm
4.3 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day , Product info support - phone consulting - 3 years
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 95% (non-condensing)
Scroll to top
